Slater
I'm talking about ATE, ATR, HD9 & ATES.
Its no longer in production.
Gotcha. What I meant was OK production may have stopped, but there is no shortage of stock from many many suppliers.
Does anyone knows whether the 2 pin male plug used on Westone, JH, Earsonics, 1964Ears cables are fit with KZ ZST recessed 2 pin female? I'm sure these 2 pins are not universal as MMCX since I've seen these plugs with different pins-end diameter/ plastic housing size, so I don't want to end up with plugs that is too big or too loose to connect to ZST.
Below is the pins I want to purchase that advertised for previously mentioned IEM brands.
Anyway, does anyone knows whether MMCX female socket are created equally? I want to buy MMCX female socket that is designed for PCB (below 1st pic) because it is like 1/3 the price of a MMCX female socket advertised for attached directly on a device/IEM (below 2nd pic). I never work with MMCX before so I'm concerned whether both have the same locking mechanism nor durability.
I'm thinking to either make 2 pins cable for ZST, or convert all my IEMs to just use MMCX instead for simplicity sake, and also because 2 pins male connector are shaped differently according to IEM recessed socket, is pretty rare and more expensive than a MMCX male plug around my place
ZSE in stock and dropped to 8$ (USD) on KZ offical ali store.
It works best on the ZST. I don't like it at all on the ZS3 or ZS5.
Personally, I don't like the sound of ZST, maybe because it's too treble-centric and somewhat lacking in bass. I think you should go for ZS5.
Seems like you quoted the wrong person/misquoted me, dude, from the looks of your post.Got a message from the seller that I could cancel my order for ZSE I made before and reorder for the new price. Very generous.Personally, I don't like the sound of ZST, maybe because it's too treble-centric and somewhat lacking in bass. I think you should go for ZS5.
Curious about the ZSE. They seem pretty small judging from pictures.
vive le difference--i can easily see why you'd prefer the kzs, but for me the urbanfun (along with the bosshifi b3 and einsear t2) have that certain hard-to-define "refinement"--they really do sound like much more expensive phones.I totally agree with your findings between the ZS5 and the ZST but I have to disagree about the UrbanFun HiFi sounding better than ZS5 and ZST from my own experience. To me both ZS5 and ZST sounds better (after pairing them to Comply T400 tips) than the UrbanFun HiFi.
As fast as internet explorer
