Does anyone knows whether the 2 pin male plug used on Westone, JH, Earsonics, 1964Ears cables are fit with KZ ZST recessed 2 pin female? I'm sure these 2 pins are not universal as MMCX since I've seen these plugs with different pins-end diameter/ plastic housing size, so I don't want to end up with plugs that is too big or too loose to connect to ZST.
Below is the pins I want to purchase that advertised for previously mentioned IEM brands.
Anyway, does anyone knows whether MMCX female socket are created equally? I want to buy MMCX female socket that is designed for PCB (below 1st pic) because it is like 1/3 the price of a MMCX female socket advertised for attached directly on a device/IEM (below 2nd pic). I never work with MMCX before so I'm concerned whether both have the same locking mechanism nor durability.
I'm thinking to either make 2 pins cable for ZST, or convert all my IEMs to just use MMCX instead for simplicity sake, and also because 2 pins male connector are shaped differently according to IEM recessed socket, is pretty rare and more expensive than a MMCX male plug around my place
