Feb 15, 2017 at 9:47 AM Post #16,114 of 63,980
yes, but someone with careless about thier iem it should not lasted that long tho but me i don't really like the way the material they use like ve monk it just look so cheap and easily be broken.
It doesn't bother me, but then again I don't really use the M3's earbuds.  I have a lot of various Monks and have yet to see any issue with damage, so while they may not look to have great build quality I have no complaints so far.  But back on track with KZ, I'd be curious to see what they'd do with an earbud.
Feb 15, 2017 at 9:47 AM Post #16,115 of 63,980
VE monk died on me cos I accidentally step on the bud. I'm extremely careless. Was thinking to buy it again but why not try new brand heh. But VE monk actually is pretty tough against twist and turn.
Feb 15, 2017 at 9:50 AM Post #16,116 of 63,980
http://www.head-fi.org/t/812853/absolute-best-budget-earbuds might be a good place to start if you want to keep with the earbud format.
Feb 15, 2017 at 9:50 AM Post #16,117 of 63,980
sure if you care about your iem you will stay longer than it should be.
Feb 15, 2017 at 9:52 AM Post #16,118 of 63,980
Feb 15, 2017 at 9:54 AM Post #16,119 of 63,980
after listen to music put it on a higher places like table to like avoid the mistake you had, dont put on the floor or else it might got you to step the iem.
Feb 15, 2017 at 9:58 AM Post #16,120 of 63,980
More like was doing house chores while listening to song, earbud fell and immediately i accidentally step on it. The reason i wanna look for another budget replacement knowing how bad I am. Lol
Feb 15, 2017 at 10:00 AM Post #16,121 of 63,980
Thanks for the link.
Beside comfortability, any pronounced difference between in ear and earbud?
Is this official KZ taobao shop?
http://m.intl.taobao.com/detail/detail.html?spm=a1z5f.7632060.0.0&id=538330941238
The earbud format due to design is not as proficient at bass production due to a lack of seal created.  It also doesn't isolate the way an IEM can.  IEMs aren't limited in the same way both in bass production and isolation.
Feb 15, 2017 at 10:02 AM Post #16,122 of 63,980
in ear is like the iem sit inside the ear with pair of silicon eartips and can give much details than earbuds.
In ear picture
Earbud is sit outside the ear for casual listening and does not give the detail like the in ear with sit inside the ear.
Picture of earbud
Feb 15, 2017 at 10:03 AM Post #16,123 of 63,980
There are many of us that would disagree with that statement.
Feb 15, 2017 at 10:11 AM Post #16,125 of 63,980
y correct if im wrong
Buy these and then tell me with a straight face you still believe that: https://www.aliexpress.com/item/Venture-Electronic-VE-MONK-earbud-earphone/32417311324.html
Until then, you are corrected.
