kokakolia
- Aug 14, 2013
not necessarily. japanese made ones from Audio technica, radius or Zero audio can stand their grounds. in fact, build quality aside i think i prefer ath clr100 and radius nef11 than any of chinese iem i've tried
also cellphones manufacturer sells decent quality iem for low price nowaday, look at the quadbeat 3 for example, its only $10 nowaday and the build quality and Quality Control is definitely better than KZ.
i think people giving chinese earphones too much credits
Yeah, that's possible. I am basing this on cheap SONY IEMS I bought at the airport recently. That's my frame of reference. They were labeled as "crystal clear sound". They had so much treble and no soundstage. The wire was also terrible. And then you look online and see 500 4~5 star reviews on amazon. Most reviews were really basic and said nothing more than "cheap, sounds good & fits well". It's the same story with the Philips SHE3590 which even get hyped up on head-fi. They sound just like the SONYs. Go figure. People don't know what they're missing!
I am sure that there are some obscure IEMs from more reputable brands out there. But it's hard to find them when the market is so saturated.
Meanwhile, I am using the KZ ED7s and thinking "if these would be any cheaper, they'd be free". It's astonishing to get good sound out of $7 IEMS. That said, the ED9s share more in common with the Philips and SONYs, namely shrill artificial treble.
