JimL11
Yeah the Carbon and BHSE are close in overall performance, though with distinct character. The main thing that turns me off about the BHSE is the 50ish minute warm up time. The KGSSHV Carbon is just $1k cheaper and simpler to use and performs in the same league, better in some ways.
Just to be clear, the tubes are only indirectly responsible for the warm up time, it's actually the solid state that directly causes the warm-up issue. The CCS heatsinks need time to come up to operating temperature, and the output voltage will drift during this process. You can measure this drift if you disable the servo in the Carbon. The tubes themselves are ready to go in less than a minute. However, because you do need to turn it off when not in use to preserve the tube lifetime, it is an issue, although due to the differential design of the amp, the balance (voltage between + and- outputs in the same channel) generally is stable within a few volts from turn-on.
The issue of changes in operating conditions with temperature occurs with both solid state and tube electronics, which is why in labs that do precision measurements, instruments are left on 24/7/365. This was true back in the tubed days, and it is true now. It is the reason why DACs work best when they are left on all the time. A solid state amp will also perform at its best when left on all the time - whether you want to pay the cost of electricity for doing so is a separate issue.
