purk
- Sep 26, 2001
The Carbon CC has been purchased already. Very fast
Very nice deal. That volume control by itself make it a better buy than the Alpha pot, IMO.
Agreed but at that price perhaps one can just get a basic carbon and a used 007. Well, for me anyway lol
Well...very true but you get a better PSU, wiring, and attenuator which in sum is more than $1000 pricetag. Then Birgir simply said it isn't neccessary. I also like the look on the chassis better.
http://www.mjolnir-audio.com/products/
"Another Carbon variant, the Carbon CC. This has been cooking for a long while now but it is basically a Carbon in a larger box with a more advanced power supply, the best volume control available and all signal wiring is solid core silver. I will only build two of these for testing, the one pictured which has a Alps RK50 volume control and a R-core transformer. The other one has a Penny&Giles RF15 volume control and my custom torodial transformers. This is meant as a project for those that think the normal Carbon is simply not expensive enough so I will continue to work on this project over the coming months. I have some things planned which will make the Carbon seem dirt cheap indeed… This is not planned to surpass the regular Carbon and I for one think that this stuff isn’t needed. It is an improvement but given the huge price difference I don’t think it is worth it. That being said, we have this drive towards “perfection” so so the crazy side of my likes to play with this stuff."
Price: 5500$ plus shipping
PS:
I'm selling Opel Corsa, year 2008 in perfect condition, price 5500$, not negociable hahahahaha
Can someone here explain whats cascaded current sourcing is good for?
Someone at the other place explain it was important and the Carbon CC does not have it - but dunno what the importance might be.
The current source, in this case, allows the active device (tube or transistor) to operate more linearly.
A cascaded current source can provide a higher resistance against the load.
The designer decides what they believe to be the best choice for their application.
The cascode is a two-stage amplifier composed of a transconductance amplifier followed by a current buffer.
Compared to a single amplifier stage, this combination may have one or more of the following characteristics: higher input-output isolation, higher input impedance, high output impedance, higher gain or higher bandwidth.
In modern circuits, the cascode is often constructed from two transistors (BJTs or FETs), with one operating as a common emitter or common source and the other as a common base or common gate. The cascode improves input-output isolation (or reverse transmission) as there is no direct coupling from the output to input. This eliminates the Miller effect and thus contributes to a much higher bandwidth.
Isn't it this?
the input circuit with the jfet and the top current source is a folded cascode.
(one of john curl's favorite things) followed by a voltage translator which the integrated circuit folks have
a name for which I forgot.
the load for the (tube or transistor) at the output is a cascade.
not the same thing.
Try and grab you while we on the subject. Do you think the additional low voltage 12v power supply boards x 2 that have been used by some on the Carbon is the better way to go, as opposed to the standard power supply feeding that 12v? What sonic benefits would you say there was to be had?
You probably right astrostar69.
Reading that it seems obvious that a cascade or shunt'ed is much better. Don't really understand why one would claim it to be better without.
Anyone heard the benefits of a shunt'ed current source? or cascaded
Isn't it this?
Is it the same as Shunt Regulated power supply?
