astrostar59
BannedMember of the Trade: Aries Cerat Espana, Auriculares High-EndAKA Headstage, headphoneweekend
A shunt regulated power supply is a completely different thing from the cascode current source, which is used as an output load.
A regulated power supply basically keeps the power supply voltage constant regardless of the current draw of the amplifier. There are two types of regulated supplies, series regulated and shunt regulated. A simple series regulator ( parts wise) is a 78XX IC chip regulator. A simple shunt regulated supply is a resistor in series with a zener diode. All of Dr. Gilmore's designs use series regulated power supplies.
Hi JimL11
Did you design the LV 12v PCBs for the group buy Carbon KGSShv? If yes, do you think this tweak on the power supply for that amplifier improves the sound quality? I am waiting for a demo of 2 amps that has both options.
