1. You DID write: "If you have audible effects (I had that on older, El-Cheapo onboard soundcards, you could hear whenever the HDD accessed sth. ) then the design of your DAC is compromised and you need to get a new DAC or think about galvanic isolation (going optical, if latency permits)." I would say a compromised design would suck.1) I never said your DAC sucks. I merely said it wasn't galvanically isolated. IMHO galvanic isolation is not necessary for home audio applications. This kind of technology is used in medical sensor equipment, so a sudden voltage spike does not get transferred to the patient. GI, as well as going balanced may help in super noisy live environments, where you have to route the signal past stage lighting etc. Nasty EMI, often too much for internal filter circuits to handle.
2) I was referring to the PSU of your external hard drive, that supposedly degraded your audio signal to such a noticeable extent.
3) You most likely didn't. I know it is very hard to accept that fact around here but human perception isn't accurate and constant enough for that.
Yes I have experienced such a change, when I transitioned from a DT-880 to a Focal Clear. Esp in the bass region, everything was a lot cleaner and more precise. Measurements confirm that it was not just a subjective impression either, Focal Clear has almost an order of magnitude less distortion in the low end than the DT-880. I have yet to hear any difference (apart from output impedance and amps driven beyond specs) between electronic source components. Measurements tell me, unless a DAC rolls off in the higher frequencies, there are no audible differences so they basically confirm what my ears already heard. As you can see: I am scientific minded. I don't trust my senses unconditionally because I know full well how easy our brain is fooled. E.g.: a 0.1dB increase in volume cannot be consciously perceived. However the brain will notice it unconsciously and translate that into improved clarity and quality. Ancient trick used by salesmen.
I don't expect you to share or understand that line of thinking of course. After all, we are wildly different persons. If you think your SD card sounds better than the HDD, enjoy the low cost upgrade.
2. Maybe but you wrote that about the dac too. see above.
3. I figured you were in the all electronics sounds the same camp. You seem to want to imply that I am not scientific. Yet say that science is dogmatic and well hearing can and can't do things. Science is adaptive and constantly changes to account for new data. I actually am being very scientific by trying to figure out what I am hearing. I am using abductive reasoning and trying to formulate an hypothesis.
One difference I heard was imaging. How does one measure that?
And really man. You think I put in a SD card and the volume was 0.1db higher and viola i duped myself into thinking the SD card sounded better when I wasn't expecting it?? Like my system would sound better everyday as the startup volume increased all the time...
