Hi, John:you may want to make the clamp force tighter fitting for the GH50- you can bend the headband in to adjust to ur head-this helps isolate and make dynamics get much much better like a light bulb going off its the ah ha moment for me.... as for the microphonic cable/band - I have since gotten the braided CLC3 wire (pic) and other custom wire for portable- the headband I had covered in some fabric like some other GH50 users- and then had Kennerton do the custom Rognir headband separately as an upgrade- it solved all that for me
Yes, I did bend the headband per the instructions in the reviews and did notice a tighter fit and slight improvement in bass and dynamics. I will try an aftermarket cable and hopefully the microphonics will be at least attenuated to some degree. I will also look into the headband cover.
Haven't heard the regular Gjallarhorn GH50 but love the JM edition. I cannot see how someone would want a +4 db bass shelf with these phones but there is no arguing in matters of taste. Thanks for all that responded.
