Hi all.
Kennerton has always heeded criticism (both positive and negative) of its headphones and has generally remedied it.
For example, the Odin mk1 had many youthful flaws: good sound, but driver reliability was lacking; it was also much too heavy and very uncomfortable to wear; very stiff pads; suspension headband was too long, too thin, not padded and not suitable for small heads and delicate hair leathers.
Correction with the Odin mk2 (much more reliable for the driver), with an improved secondary suspension headband (shorter, wider and thicker (padded)).
New correction with the Odin mk3 Thridi, with an even better driver performance (new "honeycomb" reinforced membrane); new external grid (composite material), 100 g lighter; new pads a little more comfortable (less rigid).
The sound of the Odin had to be more technical, better performing, detailed, fast and airy; the headphones even lighter and more comfortable to wear: this was achieved with the Thror, the first to use a driver with a carbon frame (100 g lighter than the classical steel fram of the Odin), followed by the Thekk (a little warmer, airy and present for the bass than the Thror); then with the Wodan and especially the last Wodan (with the aluminum driver frame, 80 g lighter than the old Wodan and its steel frame).
The Wodan and Thekk also use the new self-adapting headband inaugurated by the Magni, which is flexible, lighter and much more comfortable to wear than the old "rigid" headband equipping the Odin and Thror which is certainly more aesthetic and enhances.
There remains the current criticism of the lack of valorization of the new headband equipping all the new range of Kennerton headphones, and which is a little "cheap" for the current high-end headphones of Kennerton (Thekk and Rögnir).
Well I think Kennerton will listen to this criticism and that future Kennerton high-end headphones will be equipped with a more qualitative and valorization headband than the one equipping all the latest Kennerton headphones; they can be trusted on this subject, because they are never short of ideas and good innovations and remain always open to criticism.
