Lokiiami
ASR don't really give face, quite brutal ...
Yeah there's a lot of controversy surrounding ASR. But I mean even DMS acknowledges that the Topping sound just as good as some of his high-end gear, while lacking a bit of character, warmth, signature to them (good or bad you decide).ASR don't really give face, quite brutal ...
I am just reading through the thread now, but I am curious about you feel about your headphones many months later.First off they have much better detail retrieval over the Z1R but the Sony has more bass impact, between the 2 I like the HP-2 quite a bit more.
As for low listening levels, I'd say I normally listen around 80dB or so but do go up to maybe 85dB from time to time. They sound really good no matter what level I listen at and I do EQ the bass a little but as for everything else, there really is no need to because these are one of (if not the most) balanced headphones I've heard. Other than to compare I haven't even picked up any of my other headphones since I got the HP-2, I like them that much. I won't say there the end all be all but for headphones under $1000 I don't think any can beat these at detail retrieval and imo they're right there with the HD800s in that regard. If you like a balanced natural sound then these will work great for you.
And...you're putting them up for sale tomorrow right?Fresh arrival from Russia, brand new replacement set of Magni Headphones. Ivan and the crew at Fischer/Kennerton continue to honor their word and their warranty. I’m a man of my word and I absolutely try and always give credit where it is due. I continue to thank them for the their support in all sincerity.
Make me an offer, the box is still just like you see it in the picture. This has been close to a 2 year process for me trying to get a set that works. as far as i know these would be a dark wood set, maybe depends on what they sent.And...you're putting them up for sale tomorrow right?
I was just going by your recent statements.Make me an offer, the box is still just like you see it in the picture. This has been close to a 2 year process for me trying to get a set that works. as far as i know these would be a dark wood set, maybe depends on what they sent.
Stock pad inner diameter of ~9 cm so they are not big/wide. It is almost guaranteed that the pads are going to be a very close fit. That said, I also have fairly large ears and the pads are not uncomfortable even if your ears are pressing into the inner surface of the pads.Could anyone tell how much space do the Kennerton GH 50 (JM Edition) have inside the earpads, please? I got big ears, so don't know if they fit.
Hey, did you mean ~6 cm inside? 9 cm is very large.Stock pad inner diameter of ~9 cm so they are not big/wide. It is almost guaranteed that the pads are going to be a very close fit. That said, I also have fairly large ears and the pads are not uncomfortable even if your ears are pressing into the inner surface of the pads.
Grab them and let us know!Haven't seen a lot about the M12s, anyone have experience that could share some thoughts? Audio46 seems to have the "2020" version with the 50mm drivers for $490 on sale right now, might pick those up if they have decent feedback.
