That's a coincidence! I am listening to the Lark right now. With Kinboofi mauve 16 core cable, they sound excellent!
I read your review about Lark some days ago! It is a fantastic review!
I got the Believe in, and I gotta say I'm really surprised how bassy these are. I was expecting something more balanced, but the mid bass is overwhelming. In fact, it really doesn't sound much better than my KZ ZAX. Big boomy bass, recessed mids.
I've tried all my tips and nothing seems to tame it. Is something wrong with mine? I'm kind of shocked here because I have read very few criticisms of the tuning on these.
Are there some tips that will cut mid bass?
Spinfits, stock, stock foams. I'm not hearing much variance off amps at all. JDS Atom and MOTU M4. It's 17 Ohms and 98dB, people think that's hard to drive? My PortaPros take more than these : /Why should there be criticisms of the tuning just because it’s got plenty of bass on tap?
Not everyone is looking for a super flat tuning for classical music (for example).
Also, are you using an amp, or just some random cell phone? Because as has been stated by numerous people, it NEEDS an amp to sound correct. It’s not optional; it’s required.
Also, what tips are you using? They are quite tip dependent.
they are midbassy but most of that goes away with burn in and use the silicone tips with the orange stems.I got the Believe in, and I gotta say I'm really surprised how bassy these are. I was expecting something more balanced, but the mid bass is overwhelming. In fact, it really doesn't sound much better than my KZ ZAX. Big boomy bass, recessed mids.
Yes, I have a JDS Atom and MOTU M4. They actually sound slightly better off my LG G7 because they don't trigger high impedance mode, and with less power there's a small reduction in bass.Hi friend, did you use an amp to release Believe's potential?
The KBear Believe sound very good from the 4.4mm of the HiBy R5, but from the 4.4mm of the iFi Hip Dac the KBear Believe sound absolutely beautiful.Hi friend, did you use an amp to release Believe's potential?
I'd rather not take them apart in case I ever need to sell them. Although I wonder if the damper is what's smoothing out everything too. There's like a compression like timbre to instruments that sounds borderline unnatural. These sound like they were tuned for electronic music. I'm really not digging them for vocals, acoustic, live, or instruments. The recessed 1K region especially makes male vocals veiled, and Guitars sound "off". I think it's this recession that makes me turn the volume up, and then the bass gets some more juice and ramps up. The lack of treble doesn't help with the guitars either.Try some Azla Sedna Shorts (Light), or remove the acoustic dampers for a major boost to the mids and treble (you’ll probably have to remove the dust filters as well, which are underneath the dampers). If the latter gives you too much top end then there are lots of options for alternative dampers to get the tuning where you want it.
...and there’s always EQ.
On the way: BElieve. I had better dust off my Fiio A5......
