Kaldas Research RR 1 Conquest ($500 Electrostatic)
Aug 19, 2019 at 3:14 PM Post #211 of 719
Well these are very initial impressions, so take it with a big grain of salt L700 is a little sharper, easier to drive and has better sound stage, 3D/Holographic sound (this I believe is due to larger driver and/or my ears more used to the sound of Lambda series). RR1 have a more organic sound signature and to my ears are balanced sounding (more like a planar with little more details on few tracks). Hope this helps. :ksc75smile:
I have read from more than one impressions that RR1 sounds more like a planar. Would you say something like Edition-X? Thanks.
Aug 19, 2019 at 4:01 PM Post #212 of 719
Wow...that's a lot of praise considering how expensive the l700s are... really interested in the rr1s now
Aug 19, 2019 at 4:12 PM Post #213 of 719
Well I didn't get a chance to hear the Edition-X. But I have HiFiMAN HE-560 v3, Sundara and HE-400S, Audeze LCD2 however didn't do a lot of listening to give out more details at this point in time. Would be able to share more impressions/comparisons when get my RR1 back from Aumkar :smile_phones:
Aug 19, 2019 at 4:29 PM Post #214 of 719
Wow... would really love to know how does the RR1 stack up against the lcds and Hifimans ...
Aug 19, 2019 at 6:23 PM Post #215 of 719
This comparison is going to be tricky!
Usually, when comparing 2 headphones, dynamic drivers and/or planars - you'd use them on the same amp, so at least this very important piece in the sound chain is kept fixed or common.
But, for eStat and planar (or dynamic driver) - one cannot use the same amp! Therefore, @Lord Rexter 's comparison might not be the same as someone else using different amp for the planars.
I know this hobby is very subjective to begin with, but with this specific comparison - even the objective part is compromised!
Just my 2 cents.
Aug 19, 2019 at 9:53 PM Post #216 of 719
Just my 2 cents.
For most of the planar headphones, yes, the amp would play an important role because the planars are usually less efficient and more difficult to drive. But Edition-X is a very efficient planar headphones. It doesn't take too much to drive the ED-X to sound good (my O2 can drive it well). The other reason I am interested in comparing the ED-X is because it was one of the planars that sound more like the e-stats. At least that's how I used to think of ED-X until I got the real e-stat (Stax 4170, or SR-407 + SRM-006ts). The ED-X has better bass impacts but the SR-407 has better clarity.
So as long as we can keep the source the same and it would be an interesting comparison between RR1 and ED-X. If the RR1 can have the clarity of the SR-407 and the bass slam of the ED-X then it's definitely a big winner.
Aug 20, 2019 at 12:51 AM Post #217 of 719
Just my 2 cents.
Absolutely true man
Aug 20, 2019 at 12:53 AM Post #218 of 719
Yeah..let's see
Sep 6, 2019 at 10:38 PM Post #221 of 719
Modern day planars like the Empyrean didn't sound nearly as good as the RR1 did. I had a pair of Emperyan for a month and evetytime I did an A-B test I kept going back to RR1. My ex-girlfriend had the same impression.
What amplifier you use? For the RR1 that made it sound better than modern day planar?
Sep 14, 2019 at 4:39 PM Post #225 of 719
Modern day planars like the Empyrean didn't sound nearly as good as the RR1 did. I had a pair of Emperyan for a month and everytime I did an A-B test I kept going back to RR1. My ex-girlfriend had the same impression.
What DAC/Amp for Meze you were using when comparing with RR1? And were you using same DAC connected to KGSSHV as well?
