I get the pop sound when I play , pause or skip tracks
[KA3/KA13] FIIO X JADEAUDIO USB DAC DONGLE
- Thread starter FiiO
Dtagonkiva
Is battery drain really bad?? Is the 3.5 output also draining battery?
Battery drain is comparable to any high output USB DAC dongle. You can't ask for high output without power coming from some where. Of course, it is also relative to how loud you listen and the impedance of your headphone.Is battery drain really bad?? Is the 3.5 output also draining battery?
Isaac Rebolledo
sIf so, you are absolutely right, that's why I put (relatively high battery consumption)El consumo de la batería es comparable a cualquier dongle USB DAC de alto rendimiento. No se puede pedir un alto rendimiento sin que la energía provenga de algún lugar. Por supuesto, también es relativo a qué tan alto escuchas y la impedancia de tus auriculares.
Isaac Rebolledo
norteIt is not bad, only that it is high when the balanced output is used in the 3.5, the consumption is little¿La descarga de la batería es realmente mala? ¿La salida 3.5 también está agotando la batería?
Isaac Rebolledo
wwow we agree is many things if I am not mistaken in the majority not bad for my first review[MEDIA = youtube] qtW-QIjVvkY [/ MEDIA]
Perepep
sorry for the delay, until now I didn't have access to the old computer. Indeed, the driver you indicate is the same one that I could not install. I will send an email to the technical service to see if it can be solved.The fiio support said :
Thank you for reaching out to FiiO!
Yes, the KA3 is compatible with the Win8. You would need to install the DAC driver first: https://forum.fiio.com/note/showNoteContent.do?id=202110201505087366118&tid=77
Do you tried this driver ?
If that was your first review it was pretty good Isaac, as a side note, you don´t need to agree with anyone regarding what you hear and the only validation you need is your own, thanks for writing it.wwow we agree is many things if I am not mistaken in the majority not bad for my first review
Isaac Rebolledo
Si esa fue tu primera reseña fue bastante buena Isaac, como nota al margen, no necesitas estar de acuerdo con nadie con respecto a lo que escuchas y la única validación que necesitas es la tuya, gracias por eescribirn Thank you very much friend, it was a fairly simple review, I need to mention many things, I will see if it updated when I have time, and you are right, the review is from each person, it does not have to be all the same
Amber Rain
- Aug 26, 2016
Hi, has anyone tried the KA3 on a Mac? Are there any issues with it? How do you control the volume levels - just the normal buttons on the Mac..? I could n't find a Fiio app for a Mac.
Yes, use the volume control on Mac to control the overall volume.Hi, has anyone tried the KA3 on a Mac? Are there any issues with it? How do you control the volume levels - just the normal buttons on the Mac..? I could n't find a Fiio app for a Mac.
Amber Rain
- Aug 26, 2016
Thanks, so only the 16 discrete levels of volume then?Yes, use the volume control on Mac to control the overall volume.
Maybe this will help: https://www.howtogeek.com/265487/how-to-adjust-your-macs-volume-in-smaller-increments/Thanks, so only the 16 discrete levels of volume then?
