myinitialsaredac
- Sep 14, 2008
Harvey, if i may take a crack at your question, in stock configuration (single entry) the cable running to the right driver runs through the two beams on top of the head phone and have 4 extra solder joints than the cable connected to the left driver. This means its longer to the right (which some may argue u cannot hear due to the electrons moving at near the speed of light), but i would argue that there may be a palpable difference due to the equation that takes length of wire into account of electrical resistance. This can cause variance between the two drivers because the amps are pushing the same current into the left and right driver.
Going dual-entry rectifies all of these problems. It removes hte extra solder joints, the length to both drivers is equal, thereby eliminating differences in electrical resistance and necessary push. How much of this you actually hear is arguable, but from a scientific standpoint it makes a lot more sense to go dual entry.
For some information on electrical watts, volts, amps, ohms, etc. I found this to be quite useful for a brief article -
http://www.ebtx.com/mech/ampvolt.htm
Dave
Dave
