Leonardo Drummond
- Mar 31, 2010
Ohhhh dear... now that's definitely something to think about! A bit over my budget, but who knows!
hey called for to check for parts so I thought i would share some parts number for the K1000. hope this will help someone in future.
#02010 for large pads 26.91 each
#02020 for small pads 26.31 each
#2500Z08010 for front grill 26.42 each
#2500Z07010 for inside grill 27.55 each
Where did you call? When I contacted Harman last week they told me they no longer offer replacement parts for the K1K...confused. And what's the difference between the large vs. small pads from a comfort perspective? Sorry if these questions have been covered before I got my K1K only 2 days ago and I'm still learning about it and haven't had time to peruse all these good threads.
Thanks!
Mr.Snies is correct I called harman at first and they had no idea what the K1000 It took some time to convince them that I was an really AKG product. And yes ask for Frank, for parts.
The small vs large pads are the two different shaped pads that are on each side of the K1000, one fixed and the other adjustable.
Warp, are you saying you're trying to double up on the large pads for more pressure? You've first tried adjusting the slide of the temple pads right?
Grats on the Milezone pair btw, they are probably more NOS than even my pair based on the looks ><
