travis-bickle
- Sep 22, 2010
what should i do with the braided shield when soldering to a 4 pin xlr female socket?
Actually many headphone amp out there provide decent power for the k1000 such as the liquid gold, Masskobo394 II (I personally own), headlamp gsx (maybe)You need a speaker amp and to connect it to the speaker terminals. It's all good from there . I've got a cheap Denon Integrated Amp, I've also got a First Watt F6 Power Amp. The only headphone amplifier I've got which gives plenty of voltage to the K1000 is the Benchmark Dac1. I've taken the jumper out that limits the voltage going to the headphones . All 3 options work great
thank you. so it is the pm6006 then. will report back during the weekend.You need a speaker amp and to connect it to the speaker terminals. It's all good from there . I've got a cheap Denon Integrated Amp, I've also got a First Watt F6 Power Amp. The only headphone amplifier I've got which gives plenty of voltage to the K1000 is the Benchmark Dac1. I've taken the jumper out that limits the voltage going to the headphones . All 3 options work great
Thank you!Eddie Current 2A3 MKIV 6 watts SET Speaker/Headphone amp, if you can find one.
Personally, never had any luck with RCA out for K1000, speaker amp wins hands down.
Good luck!
There are none that I'm aware of. But if the leather is still intact and the foam is deteriorating, it's a fairly easy fix to re stuff the pads.Where can I buy replacement K1000 pads in US and what are their part numbers? Thanks.
