oqvist
- Oct 28, 2004
How hard is it to replace the headband? My biggest fear is getting that headband joint failure some is getting.
You could...
- Stuff paper towel rings under the pads to make them protrude more.
- Reduce the extension of the cups
- Swivel the cups before spreading the headband so they kinda lock in place.
- Replace the pads with Audeze pads (they're thicker).
- Add a Sennheiser HD600 headband pad. Tightens them a little.
- Go nuclear and replace the headband. Maybe a Fostex/Denon headband and attach the JVC cups.
Trying to think of my next headphone upgrade from the TH-X00s. The DX1000s seemed like a good candidate but it sounds like there are some mixed opinions on the bass, specifically that it might have less impact than the X00s and I do like impact. But the DX1000 sounds like it is better in euphoric sound (has me the most intrigued), deep bass, isolation, and more tamed treble. As someone who mostly listens to french house and various other electronic genres, would this be a clear upgrade or should I look elsewhere?
Good Stuff.
Good Stuff.
Good Stuff.
Is this better for EDM, hiphop, Top 40 or TH-X00?..
Has anyone reterminated their JVC HP-DX1000 with balanced XLR? Trying to be sure the wiring is colored and straightforward before I reterminate mine.
