JRiver Media Center 18
Oct 18, 2013 at 3:34 PM Post #256 of 289
Is it possible to make JRiver display which sample rate im playing?
I know I can  have DSP window open and it shows it, but yeah... :p
Oct 18, 2013 at 5:15 PM Post #258 of 289
I cant find a way to show sample rate tho. Id like to see whether it runs 16 or 24 bit without having the DSP window open
Oct 18, 2013 at 5:24 PM Post #259 of 289
right click on the display and choose "customize display". Reading  the help wiki is also a good idea as you might be surprised by how much customization is possible.
Oct 23, 2013 at 9:57 PM Post #262 of 289
You may want to try and set J.River to use 32bit audio as default for output to see if it will try 48K in 32 bit. This depends on your audio hardware limitation.
Oct 24, 2013 at 11:02 AM Post #263 of 289
Could somebody tell me why I'm getting this error and how to fix it?
Common error. When I swap from my DAC to my hi-fi which doesn't go through the DAC I have to switch all output formats to 44000. Go into DSP>output formats and "set all" to 44
It just means your hardware doesn't support 96 (I'm guessing a receiver since most modern computers support 96)
Oct 24, 2013 at 4:05 PM Post #264 of 289
Strange, maybe it's because of the new Windows 8.1 driver issues...I just built this computer so it should definitely support 96. It's connected to an Audio-GD NFB 12 DAC/Amp via optical.
Oct 27, 2013 at 10:36 AM Post #265 of 289
The optical might be an issue.  Does that optical cable run right to the motherboard?  It's possible your mobo/machine can only output specific frequencies.
Oct 27, 2013 at 11:00 AM Post #266 of 289
You have probably disabled WASAPI Exclusive Mode. WASAPI Shared Mode requires you to match your player's output settings to whatever the device is set to in the Windows Control Panel.
If you want automatic resampling in a non-exclusive mode, you should output DirectSound, or use WASAPI Exclusive Mode to let the player take control of the device.
Jan 18, 2014 at 12:19 PM Post #267 of 289
Anyone using JPLAY in jRiver MC?   I just tried the trial version, and within 30 minutes of listening I upgraded to the full version!
I think it is awesome!
Jan 18, 2014 at 12:27 PM Post #268 of 289
Jan 18, 2014 at 2:45 PM Post #269 of 289
You mean this?
http://www.jriver.com/jplay.html
Did you really think the jRiver would respond a different way?  There are thousands of JPLAY users.....mostly audiophiles like myself!  There is a "FREE" trial version so you can try for yourself.....but if you do, make sure to use their recommended settings and enjoy!  Nothing to fear except the wrath of jRiver!
Apr 8, 2014 at 1:50 AM Post #270 of 289
The J River MC 19 now supports 64-bit VSTs. So I am using my Voxengo GlissEQ plugin with it successfully.
(As far as the crap going on about JPlay, I just have this article to offer: http://www.computeraudiophile.com/blogs/mitchco/jriver-vs-jplay-test-results-156/)
BG
