Sound Eq
- Nov 9, 2013
Greetings
I love my JH Audio iems, and I have the Roxanne, Lola and Angie.
But I was always a bit bothered on being limited in trying different cables on my JH Audio iems
So I searched the net until I found out a great company in Singapore called Whyears that makes adapters, which allows you to use any after market cable with your JH Audio iems, and has bass boost implementation
I was skeptical first, as to whether those will work in a positive way or not, especially I wanted them to have bass boost implementation and to be as good as that which is on the original cables
Well I got the adapters few days ago from Whyears
I ordered 2 types of adapters, one to be used with MMCX cables and one with 2 pin cables
In my arsenal I have some of the cables from OC studio called the Monarch, and as well the Orpheus Mk5. Also I bought from Whyears a great 8 core copper cable that sounds amazing and it is simply a great sounding cable with great built.
I am not going to into details how each cable sounds, as the purpose of me writing this, is to help some who would love to take their Jh Audio iems to next level with cable rolling, using their own favorite cables, and that is now possible within a decent cost. Those adapter cost 66 usd, and they work as a charm with any cable I tried, simply plug your cables into those adapters and there you go, you are now enjoying your favorite cables with your favorite JH Audio iems.
The bass boost is very well implemented, simply dial in your preferred bass amount as you do on the original cable, and adjust if you like to levels you desire.
I was waiting for a great option like this since I got into JH Audio iems, as I adore those iems but always felt the stock cables was just ok, and now I can tell you with cable rolling it will certainly take your listening experience using your JH Audio iems to next levels.
Also Whyears offer now a special discount code: spc10off
that you can use at check out to get a 10% discount on your order
Simply put those adapters are so well made, and it allows you cable rolling at a decent cost
Here is the link to the adapters
https://whyears.myshopify.com/products/jh-to-0-782pin
And here is the link to their website
Do not forget to check out their great cables which are truly amazing sounding and have a great built quality
