Buddhahacker
would the wax guard mufful the sound in any way??
I didn't notice any muffling of the sound.
So what's the best way to wear these with the comply tips??
Has anyone purchased the CIEM version of the Laylas and seen a difference in SQ from the UIEM with the same source-DAC/AMP-Layla setup? I'm not sure which to get after trialing the Universal Laylas with the foam tips and CDM, it's already better than anything I've heard for classical piano/violin/orchestra.
Thanks.
Thank you. I ordered the CIEM. Service people at JHA have been wonderful.
Congrats. One thing I am not sure with the custom version though - in universal version we needed to change the eartips to Comply to get the best results, especially for low mids and bass. In the custom version, however, there is no choice. If it sounds like the stock tip version then you can't boost up the bass like we do for universal. In any case, the Layla is a very good IEM. Paired with the AK380Cu, you get a really good combo - the best of the best of the best.
