tumburu
- Nov 4, 2012
the whole point im trying to make is that it should be feasable to make IEM in the 2,000$ rough range that gives you the sound of a $300,000 mastering system, why would you make you goal to replicate a cheaper ,less accurate ,mastering system if you could aim higher and hit the mark of the high end systems that the best mastering engineers use?
i think JH audio can very well do it.
About this. It's not as simple as that. Actually it's pretty impossible. IEMs are not emulations of real speakers, nor they could ever be.
Actually ALL speaker manufacturers have the same goal. Though, results are so different.
IEM and generally headphone technology is so different, that talking in these terms is a bit naive, really. JH used a specific word: mastering 'grade', meaning accurate representation, within the inherent limitations of IEM/BA technology, which imply all his discoveries: multi drivers, phase aligned, steep crossovers etc.
In the end, as goodvibes said, there's no headphone that you could instantly master on. It's not like, from a certain level above, in the case of speakers. You'll still have to learn them, meaning how the master will translate also on speakers. For me it's simple: I want high end headphones that don't need eq. Hopefully JH will deliver. If not, someday somebody certainly will.
