PinkyPowers
Reviewer: The Headphone List
2 o'clock bass is just right, most of the time. The cable is great. The best I've used, so far.
It's personal so you'll need to listen but here's my take with admittedly only short listens to the Angie. Check the 1st page of this thread and you'll see my initial take after a few minutes listen. You'll see I got it right and instantly preferred it to Laylas on DAPs.
With stock cables, I prefer the Angie but if you put a standard Whiplash TWAG V3 cable on your JH13fps, it's hard to beat beyond personal preferences. If you try the TWAG, give it a couple hundred hours to run it before coming to a conclusion. Gives it more apparent extension and harmonic structure like the the Sirens plus more with more space between notes. Angie is a bit more midcentric but both are effectively correct with the 13 having a slight raise of the lower bass. The twag doesn't decrease the lower bass, in fact it may be more apparent as the mids clear out once run in. Its not a very 'silver' sounding cable once settled.
Hey Angie owners, I am trying to decide between Angie and Roxanne Universal fit
Right now I have 1964 Ears V6 customs, and they have a nice, rich sound, but slightly dark with rolled off treble. Alot like my Sennheiser HD650s. But I also find they are inadequate for classical music.
I am looking for an IEM to complement my V6, something with a bit more treble detail and clear highs for listening to classical music.
I suspect that the Angie would fit the bill, but it is super tempting to spend the extra 250 dollars in my case and get the Roxanne. But I heard the Roxanne were "dark" sounding which to me means they will have a signature similar to HD650, which I don't like for classical. For classical I like HD 700, or HD 800. Bright sounding phones, to reveal all the slightest details and nuance of the classical recordings. From what I have read, Angie are brighter and less "dark" than the Roxanne. Possibly Layla too, but they are out of my budget unfortunately.
Will Angie fit the bill moreso than Roxanne for classical?
I suspect that the Angie would fit the bill, but it is super tempting to spend the extra 250 dollars in my case and get the Roxanne. But I heard the Roxanne were "dark" sounding which to me means they will have a signature similar to HD650, which I don't like for classical. For classical I like HD 800. Bright sounding phones, to reveal all the slightest details and nuance of the classical recordings. From what I have read, Angie are brighter and less "dark" than the Roxanne. Possibly Layla too, but they are out of my budget unfortunately.
Would it be correct to assume the Angies are more laidback and mid-centric than the 13s?
I've seen the UERM compared favorably, also.
We all have our favs with good reasons for it. The JH13 won over it in innerfidelity's shootout but there are respected members here that have had both and prefer the UERMs leaner take. It's valid and in that best range if it fits an individual. It's a great example of tuning for balance above 100hz vs time domain. It's probably more linear than the Angie but it's impulse response (time domain) isn't as good.
UERM
Angie
I'm not showing frequency response because they can be sourced from the same place and they vary a lot by who measures them. Impulse doesn't change much if at all. Angie has a dip in the lower treble and the UERM has a bit of added treble sparkle. Neither is problematic.
Thank God I listen to music with my ears and not with my eyes using graphs or I never would enjoy anything
I've had Angie for over a month now. Instead of becoming disillusioned by it, I am ever the more impressed and content with this purchase. The only upgrade I've even contemplated is moving over to a custom shell for her.
Totally agree. It's relegated my LCD-2s to the closet. I brought out the LCDs recently because they looked lonely and promptly put them back in the closet: Angie's have better slam and presence and is more pleasing to my ear.
CJ
