SilverEars
- Sep 18, 2013
I compare with ODAC/O2, which I have ready to compare at all times.
So it's the amp section that's the problem and not the DAC? I kinda expected the reverse if anything.
I dunno, I'm comparing it to ODAC/O2 which the goal was lowest distortion, output impedance, neutral sound possible. There is a blog that proves that measurements(image captures of the FR and triggers), and my listen sessions with very high end iems such as the 334 and 836 backs it up. Higher end phones are very revealing of sources so it's easier to decern performance of the sources.
I've a/b switched between the c5d and my other amps, including my apogee audio interface, which includes a very nice apogee dac. I find the c5d to be the same excellent flat response as the apogee. The apogee is used in music studios for it's reference quality. I don't hear any differences at all. I believe most people would find the same is true of the odac and o2 if they did a blind test.
If you have a headphone that requires the greater power of the o2 you might hear a difference, but most of the earphones and headphones mentioned thus far are more than capable of being driven by the c5d. I think the biggest difference people here between amps and phones comes down to two main factors. Output impedance and expected response of their earphones.
As an example, someone might have an earphone that has recessed treble. They pair it with an amp that is brighter than normal with a less than optimal high output impedance and find the sound to be reasonably neutral to them. They get the c5d, which is flatter than most rulers, and the the low output impedance results in their earphones sounding as they were designed under optimal conditions. This reveals the recessed treble and sounds more warm to them. Thus, they then think the c5 is a warmer amp.
Or similarly, with a different earphone and amp, the earphone may have boosted treble. The amp's high output impedance dampens the treble so it sounds reasonably neutral to the user. When they switch to the c5d, the low output impedance reveals the true boosted treble response, and they think the c5d is a bright amp.
I have compared over at least 30 high-end phones in the last year with various amps and devices. I believe the c5d is an incredibly neutral amp and dac. I find no audible difference comparing it with any other good quality amp. This is based on double blind switching. The c5d will give you reference sound if you have phones that it can properly power. Sure, you can discuss "synergy" and things like that, but it is my opinion that if you are going to describe the sound of an amp itself and call it bright or warm, you need to take it out of the context of one single phone. I personally take reviews with a grain of salt if I don't know the reviewer well or they don't do any blind testing. It is too easy, even when you're aware of the effect, to think you hear something because you are expecting it. This has been scientifically shown to happen with audio comparisons.
The c5d is a neutral amp/dac with a well chosen double bass boost selection and a reasonable amount of power for most phones on the market. I don't see any problem matching an amp to an earphone you like and be happy with the sound, however, I'd get an accurate amp first and then match an earphone to the amp personally. The change in earphone will make more difference than the change in amp. And some earphones are very customizable with simple mods, resistor adapters, etc.
I must agree with luisdent, with all the headphones i've tested over a long time, i have never found the C5/C5D to be unnatural in bass, mids or highs. The highs are not over pronounced or bright, the bass is not unnatural, it is all just very linear and neutral. It doesn't alter the signature as such, just tightens and refines. Never taking away any body of the core sound signature.
It may sound this way if you have come from a relatively warm source, or from a source with higher output impedance.
From what you guys are saying it would seem my original plan to swap out my Fiio E18 and replace it with the C5D in a bid to tone down the treble and add overall warmth to my AKG Q701's might be fruitless.
That's fair enough I guess. I buy the argument that the ideal amplifier is a straight wire with gain.
Valves it is then.
