Zenthelld
- Oct 15, 2013
Yeah, both the Air and the iTouch need it to be in Battery mode or they won't work. And I'm running higher volume on low gain at this point, but was just wondering if there was some advantage to running high gain @ a lower volume. I can't tell a difference sonically...so lower is probably better.![]()
The high gain increases the impact the bass boost gives. So if you find that there isn't enough bass with Max bass boost on low gain, switch to high gain and turn the volume down. If you're fine with the bass on low gain then no other difference will be heard to my knowledge.
