Mimouille
These look nice... What is the sound signature. And why is this thread in the full size headphone forum?
I am onboard however the screw mmcx might be a turn of off for those cable enthusiast. Considering it is a dual BA the retail price is a little step. What kind of driver are you using? Is it after market or did you guy had a hand in fine tuning it to your house standard?
Thanks.
Thanks.
I tried to place an order this morning but got some sort of error, do you ship to overseas market?
Will you guys have any early promotional code for Head-fi.?
Thanks
Please send me an email at peter (at) jays.se and I will have a closer look.
We spent a year making our own threaded MMCX since the standard non threaded MMCX a bit too often get oxidation and intermittent connection. By using a threaded connector you get a firm, stable connection and our connector is also the smallest on the market. Since we design and develop our products ourselves in Sweden there is always a lot of tuning involved and that included everything from speakers, dampers, bass ports, size/length of sound tube, wax filters etc.
We spent an enormous amount of time making this design possible in order to make the worlds smallest dual speaker armature earphones with exchangeable cables. In order to make one (1) unit we need to spend more than 40 hours which might give you an idea of the work going into this product. The housing is made with metal injection molding process (MIM) which cost much more than normal CNC round shaped housings which most other brands use. The threaded removable front filter is made of 1 piece of metal with 55 laser cut holes in a diameter of just 2mm. I don't want to think about how much time we spent in sampling and tuning the acoustics in this one
From our 1st generation q-JAYS we knew people very much loved its very small size form factor and this we wanted to keep and then improve it on all parts we found needed. We have a hard time enjoying the multi IEM earphones that becomes almost bigger than your ears and that you need to spend 10 minutes just in getting them in and ready. Everyone that have used the 1st generation q-JAYS will for sure recognize all the benefits with them and now we have made them even better.
The next generation q-JAYS is now in stock.
Thx that you did offer yourself, somebody had to do itI couldn't resist, placed an order. I will likely make a separate thread of its own for it once I have my unit.
I have been in market for a good dual BA for along time. I am looking forward to pairing first with the A series walkman and later with AK Jr for complete portable setup. Ofcourse I will pair it with my other not so portable gears to test how much it can scale up.Thx that you did offer yourself, somebody had to do it![]()
It looks the business but I am worried about the fit. The Stagediver SD2 wich is in the same price league is very tight in your ear, after all any IEM stands or fall with the fit.I have been in market for a good dual BA for along time. I am looking forward to pairing first with the A series walkman and later with AK Jr for complete portable setup. Ofcourse I will pair it with my other not so portable gears to test how much it can scale up.
For now the waiting has begun.
