HDMan
- Jul 27, 2010
Thanks John, I hope I can build my next one as good as yours. What are your blue resistors you used, are they expensive?
I have noticed that running the amp with the lid on and off produces a 5v difference from the outputs, so I have been dialing it back 5v then putting the lid on and testing further. How accurate do the voltages have to be to zero.
These are my voltage readings after 1 hour operation:
Left Balance
Right Balance
Left Offset
Right Offset
P.S really need to get some KGSSHV badges, I'm on a budget so engraving is not happening.
Left Balance
Right Balance
Left Offset
Right Offset
