Victor Chew
- Feb 5, 2008
Please dont ever give up. Its a big learning curve you have here. Close up pictures of your boards.and your wiring will certainly help.
If you are happy with the dc offset and balance then you can leave the advistments as they are. I often double check at the stax jack and make any final adjustments if necessary.
What is this A8 Reaslier thing for? Interesting and curious! You said it took the sound up a few notches.
I am undergoing building KGSSHV, and I'm ******* proud of it.
http://www.head-fi.org/t/610131/michael-bean-hennyo-stole-my-money
I knew that guy was going to do something like that. His work quality was crappy, and his attitude questionable.
This is why it is worth waiting in line for something from Headamp.
Finished the inside:
What's the go with the Khozmo, is it supposed to have little pops/crackling inbetween steps while turning the knob? I think I remember someone else having this problem with there's in another thread.
Doesn't look too shabby at all HDMan, well done fitting it all in that chassis.
With regards to your problem and solution...... etiquette dictates you describe what the problem was, and how you fixed it. Next person with the same problem can read your post, rather than bothering Kevin.
Lets see, correctly assembled, correctly wired, correctly grounded.
And it works.
Looks good to me.
Much bigger pictures are required.
