Nebby
- Aug 31, 2004
Well hopefully that was a lesson learned. When multiple people tell you something is a bad idea, it's important to keep in mind that they may be right.
So that any of you feel safer helping me, I will tell you that I do not plan on powering it up and testing it myself, I will have a tech guy do the final stages for me and get it running, I simply want to populate the PCB's, make the case and fit the parts accordingly.
I only ask because I'm curious, but what happened to the tech guy that was going to do the power-up and testing? Did the deal fall through?
I know, but I am a stubborn bugger, I gave it a good shot. Got the power supply working but the channel boards just didn't get right. I will take it to the repair shop, if they can't fix it I will sell off parts and live with the SRM-727. I could keep going with it, but I just don't have the spare time.
I'm not going to gloat....... but I am going to berate you for giving up so damn quickly. Suck it up princess, and go through some proper troubleshooting!
Yup, you only can give up when you've swapped out all the parts that could be acting up and it still doesn't work. Then you just stuff a spare PCB to get the bloody thing working.
Did you use tantalum caps? Some of them are directional so yeah, that will not end well. Also stay far away from cheap caps on ebay.
I used 1uf/50V Wima MKS caps in my amps because I had them and they fit perfectly. These caps are just for local PSU filtering so pretty much anything works.
