Is anyone building the KGSSHV?
- Thread starter verwandlung
- Tags
- kgsshv
jcx
- Jul 24, 2002
a detail but noise from the 400 Ohms of source degen/feedback R is larger
and while many source may still work best with analog volume control the picture is changing
several DACs with >120 dB dynamic range are available now - for some of these it no longer makes any difference as long as 24 bit PCM is driving the DAC - and even Windows can now be set for 24 bit output even with 16 bit source: the digital volume control math quantization at 24 bits output is way below any electronics noise floor
and headphone listening doesn't reach the 0 dB SPL anechoic chamber threshold due to mechanical motion "microphonics"
since ES headphones can't reach 120 SPL, hearing noise floor with headphones on is ~ 10 dB SPL then we really don't even "need" 120 dB dynamic range with good system gain structure
Noise at full volume is usually fixed with 100 ohms in series with the wiper of the volume control.
To maintain full signal to noise, the volume control is usually a good idea. Then you turn up to
full blast the dac, and adjust the volume control for just past your maximum listening level.
El_Doug
- Nov 19, 2008
Lil' Knight
- Sep 16, 2007
Neat
gilency
- Mar 30, 2007
El_Doug, your amp is beautiful!
spritzer
Member of the Trade: Mjölnir Audio
- Aug 22, 2002
Very nice indeed.
I was doing some inventory and I found 3 KGSSHV transformers so I guess I'll have to get cracking on some more amps.
First we need to finish these two new volksamp projects though...
Been on mine for years but this was too stupid to ignore.
ignore list expanded
kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
Nice amp indeed, definitely like the back panel
Hopefully production Teflon stax jacks soon
I was referring to the noise some dac's make when they drive the input capacitance of the jfet directly
with no series resistance. Reading HDman's comments now, i think he was talking about something else.
verwandlung
Now known as satorarepotenet.
- Feb 27, 2011
This looks very nice, refined, sober, with the name on the back! How many of them are you planning to build again?
El_Doug
- Nov 19, 2008
Thanks for your kind words, everyone! There actually will be a "KGSSHV" on the front, it is on the faceplate of the power supply (same size box). However, just like the amp, the PSU front panel will be covered with black enamel and a matte clearcoat (just primed it tonight, actually) - thus the engraved "KGSSHV" will appear as a textured relief, but will not be a different color.
It'll look even better once I get my wife to use her camera + photography skills, instead of my point-and-shoot technique with my cell phone
Is this an onboard or offboard build? Pics of the insides too please
El_Doug
- Nov 19, 2008
offboard, of course
offboard, of course
Very nice, what relay switching board are you using for the input selection?
offboard, of course
kevin gilmore
- Jun 21, 2001
I like it even more after that last picture.
Victor Chew
- Feb 5, 2008
Very nice . Any PS pictures?
