rodders
- Sep 4, 2012
Hmm. I used virtual XP, but that didn't solve my problem. Try the installation from another machine if you can.
thanks but cant even get it into umsboot now
r859 is the latest I could get. I know there are some builds after this version but the links I can find seem no longer available. By the way, I used a Windows XP running on a virtual machine on top of a Mac OS X. The USB connection/mount could really get flaky.
Hello guys,
I just bought a used iPod Classic 120GB (2G) and installed Rockbox on it a day after. It works like a charm (kudos to every single person involved!)...
...except Doom. You probably are aware of that bug. When you click play, the OS get stuck while "Starting graphics engine" (http://www.rockbox.org/tracker/task/12721 - not my bug report though).
I tried to search a solution but found nothing useful. Well, in this thread there are some hints that turning of "user timer" fixes it, but I don't really understand what to do.
Can anybody help me?
[...] i am using latest build "rockbox-ipod6g.zip" from rockbox.org and i get Left and Right music channels swapped!!!
I so want to install this on my 7th gen but it scares the hell out of me lol.
I was running it on a 4th gen imod no worries but for some reason after reading bits ams pieces on here it scares me lol
So I installed Rockbox, and I love the features so far. That being said, the battery on my ipod drains really fast now. Does anyone have any suggestions for a specific build or changes I can make to alleviate this? I am running Emcore r859 and a daily build from January.
Use a daily build: http://www.rockbox.org/dl.cgi?bin=ipod6g
