lemon56
- Oct 29, 2012
is it normal to hear the ipod restart noise sound every 4 mins?
Do you mean the hard drive spinning noise or other?
Like others posted, we assume you mean the sound of the hard disk spinning up to load new songs and spin down a few seconds later.
This is normal behaviour as the flash memory is filled with songs until they're all played and the hard disk needs to be accessed again.
However, every 4 minutes is quite often, unless you're playing very high quality (+2,000kbps) music.
If you go to System -> Rockbox Info, you can see the buffer size (usually around 55-60MB). Based on the bitrate of your music you can now calculate how many minutes of music the flash memory can store.
Also make sure that your Directory Cache is enabled: Settings -> General Settings -> System -> Disk -> Directory Cache -> Yes
Interesting... Can that buffer size be increased? I?m wondering if it would be a good idea to increase the buffer size for those like me who are just using FLAC files?
Also, does anyone know if defragging the Classic's hard drive will improve it's performance (as it does in computer hard disk drives)?
The buffer size is all the free RAM on the system, so you can make it very slightly larger by not using things like the database. But otherwise no, you have a fixed amount of RAM.
Defragging probably helps if the disk is highly fragmented, however since mp3 players a rarely written to except to copy music, they do not typically become fragmented unless you're using them as an external hard disk on the PC very frequently.
I haven't had time lately to spend on make other changes. I just sync'd with latest RB commit and applied my patches:
https://www.dropbox.com/sh/bnavehlrmgh0zlt/OJqZGzLrEb
oh yeah, that makes more sense...i though he was talking about some static
I've got prominent hiss when using my Heir 3.Ai's that pretty much makes it unusable.
actually its great, but, sorry, too buggy for me, it's turn me mad sometimes while I enjoy played music, maybe will try it later after several fix and stable version of rockbox.
roll back to original firmware...
still use rockbox on my sansa clip+
This only happens with the 3.Ai on the iPod? Have you tried the 3.Ai with another source or other IEMs wiith the iPod?
