h.rav
- Jan 21, 2009
Originally Posted by SoupRKnowva /img/forum/go_quote.gif im almost certain that it does, its just iTunes wont encode it, you have to use XLD. But iTunes will play the files once made i think. Dont quote me on that though |
Originally Posted by krmathis /img/forum/go_quote.gif Yes, it does. It does not stop there either, as it does 24-bit /192kHz as well. The iPods and hence I assume also the iPod do support a bit depth of 24-bit, but not a sampling rate above 48kHz. I quote you, in a friendly way. Just to say that iTunes is fully capable of encoding 24-bit/96kHz and even 24-bit/192kHz files to ALAC. |
Originally Posted by SoupRKnowva /img/forum/go_quote.gif Dont know if anyone else has seen this, but it suggests that the iPad might be getting USB audio support with the camera adaptor kit! Apple looking to hire camera expert, iPad Camera Kit to support USB audio? -- Engadget |
Originally Posted by Mr Do /img/forum/go_quote.gif Here's my way around this by using my ipad to control a mac mini connected to a Havana dac. |
Originally Posted by Pepsi /img/forum/go_quote.gif Well the macbook pro's audio line out supports it, shouldn't that mean the sources it carries should be able to also. If not then that feature is rendered useless. |
