fidgeraldo
Doesn't this one look like a buffer? It's the size of the buffer, not the pre-amp.Psvane’s CV181-T MkII
OK, thanks!I’m going by the specifications that I see on xDuuo’s web site for TA-26S, which lists Chinese 6N8P for preamp and Chinese 6N5P for buffer. 6N8P is cross-compatible with CV181 and 6SN7. 6N5P is cross-compatible with 6AS7.
CV181 and 6AS7G both happen to be, “Coke bottle,” glass envelope vacuum tube designs, but the pin-out, signal, heater specifications et cetera are not the same.
-Ed
This is the right pairing.OK, thanks!
This is a complete mess for me...
But I read the specs, and this CV181-T MkII seems to have a diameter of approximately 31.5 mm,
which is the diameter of the base ready for sockets of 30.5 mm.
I think that 30.5 mm could be the diameter of the sockets for the pre-amp in TA-26S.
So it could be the right one.
OK, do I have the right pair if I buy that "winged C" as a buffer and CV181 as a pre-amp?
I am bothering you, but just this one...and I am leaving![]()
Thanks a lot!This is the right pairing.
A good idea to avoid problems with the CV181 glass envelope making contact with the chassis is to use an octal tube socket saver between the tube and the socket. It will raise the base up and lift the bottom of the glass envelope past the top of the chassis. I am actually planning to do this with my Freya+.
-Ed
Haven't noticed that, I usually crank it with headphones and lower/increase volume with e50 dac. But I always use at noon as a preamp with speakers and haven't noticed that, bass definetly increases (in a pleasing manner) but nor brightness to my earsDoes the amplifier have no rise and brightness at medium and high frequencies?.I especially don't like it when it's in the middle.All the tube amplifiers that I had previously had a problem as a minimus with medium frequencies.Please write to the owners.
Thanks for the feedback although the 1600 mw that the Q15 puts out is probably plenty for the Sennys. I have to try an OTL tube amp before I do anything else.I have HD650 and I use it with Xduoo XD05PRO portable dac/amp. I really love the sound from this XD05PRO (have both dac cards with it "ESS9039SPRO and AKM4499EX"). I also tried my friend's OTL amp "Rada Valkyrie" and I can say that I like overall sound signature and tonality better with tube amp for specific genres liks Vocal Jazz, Classical Music, Blues, Soul and etc... tube amp just has different sound signature compared to my XD05PRO with AKM4499EX dac. Tubes make sound warmer, even more analog sounding, with wider and deeper scene, overall sweeter sound. But with some music genres like Metal, Electronics, Hard Rock I would not choose tube amp.
I would not reccomend you buying Fiio Q15 specifically for your HD6xx or HD600, because these cans need more power to sound really good and Q15 is more suitable for IEMs regarding its power output.
I am confirming that theory. I just tried HD600 on both outs, and it's the same.The TA26s is single ended also, it just has a 4.4 mm headphone jack for convenience. Every review I've seen of the TA 26s says both the 4.4 and 1/4 inch outs sound the same and have the same power.
I agree that 1.6watts is enough to drive Sennheiser cans. Some of the solid state amps I used previously were rated lower and it was fine. Basically anything 1watt or higher is enough.Thanks for the feedback although the 1600 mw that the Q15 puts out is probably plenty for the Sennys. I have to try an OTL tube amp before I do anything else.
keep in mind, that a balanced amp would need twice more tubesOne thing I can say is that even though it is running single-ended, the TA-66 provides more than enough power for the HD 6XX. I was a little disappointed that they don’t offer a fully balanced version/output, but for such a short cable run, I think the difference is minimal since there is more than sufficient power to drive anyway.
-Ed
Given that I own a Schiit Freya+ and that uses four tubes, I clearly don’t mind.keep in mind, that a balanced amp would need twice more tubes
I actually did the opposite, ordered the Ta 26s figuring that it was expensive and more powerful so the ta66 might be a little brother to the Ta 26s, however I ordered 220v version so I canceled to order again. Before I did though I realized the Ta 66 was actually bigger and heavier, also took noticed that those who owned ta26s commented that it was Un usable past noon due to being too much power for anything and distorted badly past that point and many reviewers noted that even though it sounded nice it was not very tubey (whatever that means) with stock tubes. I own l50 e50 stack so the farther I can go from clean precise digital sound signature the better (for variety) and pulled the trigger on the Ta 66. Glad I did, this is my first tube amp (for headphones) and it does seem pretty tubey to my highs rounded off but with all the detail, lush midrange, boosted smooth bass and effortless feeling all that with stock tubes. Curiously enough I kind of want to buy the Ta 26s as well since I bought a pair of vintage tubes for 26s before I realized my mistake and was unable to cancel that order but I can tell you that even if I buy 26s the Ta 66s is not leaving my desk any time soon. Also the volume pot is by fixed steps so you can use sensitive headphones without encountering channel imbalance at low levels (ta26s)Hi,
I was about to buy TA-66 but changed my mind at the last minute and bought TA-26S.
At first, I didn't pay close attention to outputs,
but then I saw that TA-66 has only 6.3 mm, and TA-26S has + 4.4 mm.
And the max power of TA-26S is 2.5x more than TA-66.
So, do I like the sound of TA-26S?
Yes, absolutely, yes...but I am also surprised by the sound signature.
It's not tubey/warm at all
Does anyone have experience with both to compare them?
Is TA-66 warmer sounding, different sounding than TA-26S?
I am about to replace stock tubes with ones with more tubey/warm sound.
Edward Ng, is TA-66 warm sounding out of the box?
How many pins do TA-66 sockets have...I've seen those tubes that you bought.
The front has 9 pins, and the rear has 8 pins.
TA-26S has both sockets with 8 pins.
Now, something crossed my mind...since I do like the sound of the TA-26S,
I thought if TA-66 sound different/warmer/tubey out of the box,
I might buy TA-66 rather than the new tubes for the TA-26S, which might cost the same as TA-66.
Then, I would have two great amps with two sound profiles instead of one and two pairs of tubes.
Also, I am unsure if changing the tubes with TA-26S would bring about a noticeable change.
That's what I read, a couple of comments on the TA-26S thread.
Cheers!
Which headphones did you try with it?I actually did the opposite, ordered the Ta 26s figuring that it was expensive and more powerful so the ta66 might be a little brother to the Ta 26s, however I ordered 220v version so I canceled to order again. Before I did though I realized the Ta 66 was actually bigger and heavier, also took noticed that those who owned ta26s commented that it was Un usable past noon due to being too much power for anything and distorted badly past that point and many reviewers noted that even though it sounded nice it was not very tubey (whatever that means) with stock tubes. I own l50 e50 stack so the farther I can go from clean precise digital sound signature the better (for variety) and pulled the trigger on the Ta 66. Glad I did, this is my first tube amp (for headphones) and it does seem pretty tubey to my highs rounded off but with all the detail, lush midrange, boosted smooth bass and effortless feeling all that with stock tubes. Curiously enough I kind of want to buy the Ta 26s as well since I bought a pair of vintage tubes for 26s before I realized my mistake and was unable to cancel that order but I can tell you that even if I buy 26s the Ta 66s is not leaving my desk any time soon. Also the volume pot is by fixed steps so you can use sensitive headphones without encountering channel imbalance at low levels (ta26s)
Tldr ta66 is definetly on the warm and tubey side out of the box and deserves a place in my desk with the only downside being that you loose the ability to use to headphones at the same time on it (since it's not truly balanced)
Someone above already noted that neither is balanced; it's just that TA-26S has a 4.4 mm option.Tldr ta66 is definetly on the warm and tubey side out of the box and deserves a place in my desk with the only downside being that you loose the ability to use to headphones at the same time on it (since it's not truly balanced)
