cleg
- Oct 14, 2011
My video about TUX 5
I have the same question. Did anyone have the experience with this problem ?Anyone try any other tips with their Falcon? Wasn’t sure which comply tips would fit.
Read the earlier threads and some mentioned Comply Truegrip or Acoustune AET07.Anyone try any other tips with their Falcon? Wasn’t sure which comply tips would fit.
Hi, can you be more specific about which model? I tried to find it on amazon but could not decide which one to buy ?Try the Truegrip pro foam tip from comply。They're ultra comfortable and isolating. They're very durable too compared to normal comply foam tips
A few things I have to say about the Falcon. I really like its sound signature, even though it can be slightly rolled off at the treble end at least with the Truegrip foam (which I like because it stays in the ear better and help elevate the bass a bit). When it comes to phone call however, the cVc noise cancelling function is pretty atrocious. While I can hear the other caller just fine, they often have trouble hearing my conversation because the mic picks up so much of the outside world. I assume I don't need to turn the noise cancelling on, do I?
Anyone else have issues with phone calls?
any update on the release of the app for the Falcon
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
Hi all,
If you are on Google Play, the app should be available as "Noble Sound Suite" by Noble Audio. I believe it is up for ios, but if you happen to have an Apple device and can confirm, let me know! The team making the app is based in the West and different countries mean different release dates.
Thanks for your patience!
Hi all,
its not working for me eitherHi Sebastian, so my Falcons are on, I can listen to music/podcast just fine, but the Noble sound app can't find it still. What canI do to fix this?
