- I can only recommend the following mods, because the sound gets improved and these mods are easy to be done: 1), 2) & 4).
- Also, some other improvements might be considered, though the sound don't get improved: 5), 6), 7)
- Despite the sound gets improved, I'll make the mods 8), 9) and 10) optional, because of the complexity and risks of damaging electronic components or the entire amplifier. An easier and maybe better solution would be to replace the default LME49860 with OPA1652 (these op-amps can be powered from +/-18V and the amplifier will benefit of a lower background noise).
- Mods from 11) to 16) are quite complicated and there's a high risk to damage the amplifier for good, so can't recommend these mods, unless you really know what you're doing and if you also have a multimeter and a scope around. If you don't have a scope and perhaps a frequencies generator you should probably not touch the low-pass and high-pass filters because you can't verify if the mods have been successfully or not.
- Mod 3) is really dangerous to DIY and electricity hazard might happen, so I don't recommend it! Instead, please use a power strip with common-mode filter inside or change the inside power outlet with one containing common-mode filter within. You can also get an isolation transformer with common-mode filter inside or outside, this way you'll also remove any possible ground loops you might have in your audio chain.
Per
https://www.head-fi.org/threads/int...-review-to-follow.770610/page-4#post-12120336:
- 1) Installing G.O.S.S. (
Grain Oriented Silicon Steel) to shield the toroidal transformer. This will remove a bit of existing hum from the right channel (which can only be heard with very sensitive cans and volume to the max. without input source connected).
- 2) Replacing 2.2uF WIMA MKS 4 (Metallized Polyster) with JB JFX Premium Film Cap (Polypropylene Film) or with 2.2uF
Audyn Plus, preferable 4.7uF, per
https://www.head-fi.org/threads/int...review-to-follow.770610/page-21#post-14121897.
- 3) Installing EMI/RFI noise suppression filter (one stage common-mode filter) to reduce any possible noise injection from mains into the audio chain.
Per
https://www.head-fi.org/threads/int...-review-to-follow.770610/page-5#post-12157815:
- 4) Adding more decoupling caps at the backside of the PCB, between op-amp's V+ & GND and V- & GND.
- 5) Adding Arctic Silver MX-4 thermal paste (overkill, I know) to the output stage transistor's heatsink.
Per
https://www.head-fi.org/threads/int...-review-to-follow.770610/page-5#post-12178996:
- 6) Adding 2 heatsinks above the 2 op-amps to better dissipate the heat.
- 7) Swapping the 4 existing heatsinks from above the 16 SMD transistors with bigger ones (I've used Arctic Alumina bi-compound, but I strongly recommend thermal dual-scotch tape instead of Alumina). Also, ignore the fan I've installed in there, I don't recommend it.
Per
https://www.head-fi.org/threads/int...-review-to-follow.770610/page-7#post-12390513:
- 8) Swapping the original JRC7818/7918 power regulators with NJM7815/7915 to lower the voltage from 36V to 30V, so I can install more op-amps to roll. You will loose a bit of the output power, there's
enough juice left in there.
- 8') Same from above, but with
very low noise regulators from Sparko.
- 9) Installing BURSON SS V5 duals to increase the soundstage, clarity and depth. Also, case needs to fit well, so
some adapters could be used, preferable originals from Burson if possible.
Per
https://www.head-fi.org/threads/int...review-to-follow.770610/page-19#post-13830489:
- 10) Installing BURSON SS V6 duals to increase the soundstage, clarity and depth. Also, case needs to fit well, so you could use
some adapters (preferable originals from Burson if possible) or loose the warranty and remove op-amps shells to lower their height enough to close the case.
Per
https://www.head-fi.org/threads/int...review-to-follow.770610/page-20#post-14100120:
- 11) Cutting backside PCB traces from the XLR plugs to the input caps, then further to the ALPS 4-gang potentiometer and getting the audio signal through good quality copper shielded wires. This way hiss and noise decreased a little bit; after all, I'm speaking of more than 20 cm of PCB traces (on expensive amplifiers input potentiometer is positioned nearby the XLR plugs and a metallic extender from the volume knob is used to adjust the volume).
- 12) Swapped 2 x BURSON V6 Classic opamps with 2 x OPA1652 installed on DIY SOIC-DIP8 adapters to further decrease background noise (some noise was audible only when using high sensitivity cans combined with highest gain setting of +20 dB). It's not much of a difference the 2 opamps, but there's a slight barely audible improvement (it's easier do check when swapping only 1 opamp only, then left headphone will have a different hiss/noise vs. the right one).
- 13) Increased treble roll-off frequency from 20 kHz to about infinite by completely removing the Low-Pass filter. Not quite recommended because some input sources might oscillate and deliver ultrasonic sounds, but in my case I'm safe...I know what DACs I got at home.
- 14) Decreased bass roll-off frequency a little bit by replacing the 50 kOhms input XLR resistors with 150 kOhms resistors (there's a high pass filter created by resistors and input caps). Ideally would be not to touch these resistors, instead to swap the input 2.2 uF caps, but I couldn't insert bigger caps inside the HPA-3B case...maybe some other time will do that too.
- 15) There was a slight channel imbalance no matter the gain I used, so I had also resolved this from the gain stage from nearby the 2 opamps. Basically, there are 4 x resistors (around 5.4 kOhms each) that are connected between pins 2/6 and GND for each opamp, so decreasing a little bit these resistors will increase amplifier's gain. I did that by adding in parallel 4 more resistors (48 kOhms each) on the back of the PCB.
Per
https://www.head-fi.org/threads/int...review-to-follow.770610/page-21#post-14121815:
- 16) Replacing
resistors R10, R1, R13, R14 of 10kOhms with 270ohms resistors for further decrease amplifier's noise (this might increase the existing channel imbalance, so take this mod with a grain of salt).
Per
https://www.head-fi.org/threads/int...review-to-follow.770610/page-21#post-14127810:
- 17) Replacing
TTH BC550/BC560 lower just a little bit the background noise of the amplifier.
