raoultrifan
So, I did a bit of "modding" last night:
- 1) I had replaced WIMA MKS 4 (Metallized Polyster) with JB JFX Premium Film Cap (Polypropylene Film) bought recently from TME.
I might be inclined to tell that trebles are a bit more upfront and detailed now, but to be honest without proper A/B testing it's quite hard to tell if any real difference occured. Anyway, acording to audiophile forums & resources Polypropylene is better than Polyester, so I'm pleased that I swaped Wima with JB (I was tempted to use MIFLEX MKP10 or MKP11, but they were too big to fit properly). Caps links: 1, 2, 3, 4, 5, 6.
-2) I had installed G.O.S.S. (Grain Oriented Silicon Steel) to shield the toroidal transformer.
Initially, with my sensitive AKG K550 and without any source connected to XLR inputs, when using +20dB gain setting I was able to hear a bit of a hum noise when volume pot was at 3 o'clock or more, especially on the right channel. Now after partially shielding the transformer that noise is COMPLETELY gone!
-3) EMI/RFI noise suppression filter got installed as well, but that made the amp to get a bit of hum noise again, perhaps because the AC lines were too close to XLR inputs (also, PCB traces from XLR were right besides the noise suppression filter). So, I moved the filter from right to the left side, just above the 120/230V selector, as the red arrow shows (sorry for not providing a picture of the actual noise suppression filter positioning, but I was quite struggling with fitting the filter inside the case and I totally forgot to get another picture). Also, please ignore the big red wire, it was connected to the 2 Y-capacitors, but it's not really needed, so I removed it from lack of space (it also did a quite nice short-circuit with flame, so next time I'll be more careful).
-4) Arctic Silver MX4 thermal paste has been correctly applied between transistors heatsinks and the case, just to be sure thermal transfer is OK (just realized that outer side of both heatsinks were not perfectly flat, so thermal paste should help a little bit here).
Burdie, feel free to have a look to my DT880/600. Now that's what I call shiny headphones!
Perhaps on Friday I'll receive some decent mash sleeving from Distrelec/Austria and I'll see if I'll dress those phones or not.
L.E.: Re-edited few pictures for better understanding of what I've did.
WARNING: Mod 3) is really dangerous to DIY and electric hazard might happen, so I don't recommend it! Instead, please use a power strip with common-mode filter inside or change the inside power outlet with one containing common-mode filter within.
