Introducing the Matrix M-Stage HPA-3U and HPA-3B, review to follow!
Jun 7, 2015 at 3:24 PM Post #16 of 439
Can you confirm the information in this thread regarding the warranty if I purchase from you? Would I need to ship the unit to China if it was in need of repair?
I am currently base in Chicago IL, so you can send returns and repairs to Chicago instead of China. I'm shipping the HPA-3 from China (directly from Matrix) for now because I am not yet able to stick it in Chicago and Amazon. It doesn't really matter because delivery usually takes only 3-5 days from China to most part of US.
"matrix-digi-usa" is a distributor like I am. I offer the same level of service and warranty.
Jun 7, 2015 at 3:26 PM Post #17 of 439
Wonderful, thank you for the helpful and insightful info. I will be placing my order at some point next week.
Jun 14, 2015 at 4:29 PM Post #18 of 439
Anyone have a listen to this dac/amp yet and can give a first impression?
Jun 14, 2015 at 10:26 PM Post #19 of 439
I may or may not be the first in the US. Maybe?
Anyway, it seems rather neutral from mids to highs with a slight bass warmth. Lots of power.
Jun 14, 2015 at 10:38 PM Post #20 of 439
Did you own the hpa-2? If so how similar are they?
Jul 8, 2015 at 11:10 PM Post #22 of 439
Any review/owner on HPA-3B yet? I emailed Matrix to find out more details on HPA-3B, and received very short reply from them.
1) my most concern, silver version? There is no plan for the silver version
2) Opamps? LME49860......, well, I have some TO-99 LME49720....and dip-8 socket
3) Sound? nature... errrrrr please elaborate more...
4) able to use Neutrik RCA to XLR adapter? we used YongSheng....   hmmm didn't answer my question
without much info or reviews, I proceed to order 1 unit, should be arriving tomorrow.
Jul 9, 2015 at 8:29 PM Post #25 of 439
  Review posted on post #2!
In fact I am looking at the HPA-3B, the balanced headphone amp. I am not interested in HPA-3U as I already owned Matrix mini-i pro 2014 which I believed should be slightly better than 3U in term of decoding etc.
Hopefully HPA-3B won't be far away from HPA-3U in sound signature as the warm sound is what I looking for.
Jul 10, 2015 at 5:58 AM Post #26 of 439
Today I received the Matrix HPA-3B (balanced amp), it came with 1 x power cable, 2 x RCA to XLR adaptor, 1 warranty card and 1 CD.
rear view, 2X 3 pin XLR balanced input. The toggle switch for gain stage seems sturdy
Front view, the volume knob is fastened by hex bolts, so replace with good looking volume knob won't be a problem. (I don't really like the original volume knob, I also change the volume knob of my Schiit Mojo)
China made RCA to XLR adaptor, both adaptors came in white RCA head. They don't have red RCA head?
Are you on par with Schiit Mojo in driving LCD 2.2? Well, may be need some break in.
It has enough power to drive LCD 2.2, I obtained same level of loudness at around 10.30 - 11.00 o'clock for both HPA-3B and Mojo. The sound of HPA-3B is slightly warm (what to expect from Class A amp), lows are tight but not as deep as Mojo, highs quite clean but still behind Mojo. I will try swapping LME49990 and LME49720 to see any improvement or not.
Jul 14, 2015 at 12:38 AM Post #27 of 439
Wow thank burdie! Now this is the review that I was looking for. I'm also interested in the 3B and you nailed my concern regarding the xlr inputs with detailed pics including accessories. And like you, my preference is a warm sounding amp.
I am wondering if it's a good synergy with the HD800? Will keep an eye on this. Subbed!
Jul 14, 2015 at 10:05 PM Post #28 of 439
The Interior of Matrix HPA-3B
The transformer, fuse holder, voltage selector, 2x XLR input
6.3mm/4 pin XLR - gold plated contact
PCB version 1.1
Nichicon KG Gold Tune 4700uf 35V
Wima MKS4 cap, will MKP10 improve it?
opamp LME49860 x 2
TOSHIBA audio expansion flow tube A1358/C3421, normal headphone amp uses 2 pairs, but HPA-B uses 4 pairs (for balanced?) one pair capable to drive 60-80 watts, no wonder the casing is so 'hot'
The Exterior
Volume knob (replaceable)
We hardly see people upload the bottom of any product, here it is.
Little Mob
Opamp swapping, replace the stock LME49860MA to TO-99 LME49720HA, same specs but some people claimed that TO-99 metal can package used better silicon die. Well, will you believe that it gave better transparency and clarity especially in my LCD 2.2? With this metal can, it came closer to Schiit Mojo... This weekend I will try LME49990 (bundled with the disposal of iBasso PB2, this weekend will borrow it )
highly recommend to replace the ugly stock volume knob, I put in the stock volume knob from Schiit Mojo and I think it look better. The stock knob measurement is 31mm*24mm, replacement volume knob with standard sizing of 30mm*22mm will fit perfectly. The shaft is 6mm (D) and 19mm (L).
Jul 21, 2015 at 5:11 PM Post #29 of 439
I like the stock better :P
But great reviews! Brings some fond HPA2 memories :)
