Introducing the Matrix M-Stage HPA-3U and HPA-3B, review to follow!
Aug 31, 2016 at 1:13 AM Post #181 of 439
Hi guys,
Here http://www.head-fi.org/t/770610/introducing-the-matrix-m-stage-hpa-3u-and-hpa-3b-review-to-follow/90#post_12390513 I wasn't able to close the upper case of my MATRIX HPA-3B headamp, because BURSON SS V5 dual op-amps are 2mm higher then it should be to properly fit inside the case. So, I did some "custom cables" to connect them and bend the wires to 90 degrees, so I can close the case properly.
For those interested in purchasing BURSON SS V5 op-amps for MATRIX HPA-3B I strongly recommend them to purchase the special adapters with small cables and DIP8 sockets to properly bend the V5, like in the above pictures. I do not recommend you to DIY those adapting cables like I did, because there's a high chance of getting some short-circuit or the induce oscillations.
The sound is the same like we all know: detailed, non fatiguing, open soundstage and very transparent.
Temps with case open were: 59.5C on the bottom op-amp and 61.9C on the top op-amp. Will see if I can measure the temps with case closed in the next days (I have a small temperature probe for this, just need the time to do it).
Regards,
Raul.
P.S.: When working late and tired I might break up some things: I had inserted the top V5 into the DIP8 socket vice-versa (don't ask me how I could do this rookie mistake, please). Looks like there's some sort of protection inside the V5, because it didn't blew away like I would expect from an op-amp that is powered to the wrong pins and this is a very good thing I'd say! Also, some protection is probably installed in the MATRIX HPA-3B, because nothing wrong happened with the headamp. I only powered the HPA-3B for 1-2 seconds, then I realised the issue (one resistor or one diode got smoked a bit, but I measured both and they're within parameters). After this issue I've tested my HPA-3B with my 600 ohms DT880 at extreme volume for over 2 hours and I'm happy my headamp is still within parameters. :)
L.E.: Do not try to install BURSON SS V5 or V5i in MATRIX M-Stage HPA 3B if you haven't lowered the voltage from +/-18V to +/-15V by replacing the 2 power regulators! The mod is quite simple and is perfectly covered here: http://www.head-fi.org/t/770610/introducing-the-matrix-m-stage-hpa-3u-and-hpa-3b-review-to-follow/90#post_12390513.
Sep 8, 2016 at 10:34 PM Post #182 of 439
Here we go! Just finished modding my HPA-3B.
My main reason for this mod was to lower the voltage to allow me to swap other op-amps. I went with Sparkos Labs discrete regulators in 15V.
Here is the completed board.
And here it is ready to test. I am running Sparkos Labs discrete op-amps.
I will get some listening impressions in a little bit.
I must confess that I almost forgot about this post. :)
I would be interested on how does it sounds now, comparing with what it used to be before this mod. Also, if there's a scope around you, I would love if you could measure the RMS AC ripple & noise after Sparko's regulators.
Oct 4, 2016 at 3:38 AM Post #185 of 439
Does anyone ever tried both balance and the unbalance at the same time on the HPA-3B?
I may need this features if I am going to purchase another headphone in the future, may sometimes just swap around for A/B testing or just pure listening without the hassle to unplug the other headphone out.
Thank you in advance for info.
Oct 8, 2016 at 11:20 AM Post #186 of 439
I did, but not in the same time because I can't do A/B test between 2 different plugs on the same headamp, instead I swapped headphones plug from balanced output to single-ended/balanced adapter that was connected to single-ended output (I do have a BAL to SE adapter).
I've noticed a larger soundstage, no matter the headphones used (AKG K550, AKG K701, BYERDYNAMIC DT880/600ohms); also the output power was much higher in balanced mode. I do prefer balanced over single-ended.
Oct 14, 2016 at 1:56 PM Post #190 of 439
Sorry, PCBs look the same to me, maybe you missed some of my previous posts like http://www.head-fi.org/t/770610/introducing-the-matrix-m-stage-hpa-3u-and-hpa-3b-review-to-follow/60#post_12157815 or http://www.head-fi.org/t/770610/introducing-the-matrix-m-stage-hpa-3u-and-hpa-3b-review-to-follow/60#post_12178996 where I replaced the original black radiators with bigger ones.
Oct 14, 2016 at 4:38 PM Post #191 of 439
Oct 23, 2016 at 9:24 AM Post #192 of 439
Just a heads-up I recently listed mine for sale here: http://www.head-fi.org/t/822524/m-stage-matrix-hpa-3b-modded-w-extra-op-amps
Oct 24, 2016 at 9:40 AM Post #193 of 439
Hey Matrix owners, just stumbled onto this unit and I'm curious to know if anybody has experience with the "plus" version now being offered on Massdrop?
https://www.massdrop.com/buy/matrix-hpa-3u-dac-amp
Looks largely the same, but if memory serves they did this drop a few months back so maybe someone can offer some insight?
Oct 24, 2016 at 10:38 AM Post #194 of 439
That unit has a built in DAC, not balanced with less power. Can't give any insight into how it sounds though.
