I just discovered EF400 in local audio store. It's sound attracted me from the first listening
so I borrowed it for a week. After some testing I have some first conclusions (sorry, but I didn't check all previous posts in here, there is quite a lot):
//Source is my PC with Tidal Hifi Plus and Roon by proper USB cable
///Headphones used: GoldPlanar GL2K-D, Sundara, ATH W1000Z, ATH W5000, HD600, iBasso SR2, Denon D7200
1) I think it is already well known and I can confirm -
balanced outputs here are much better (cleaner, more precise sound). SE on some headphones is very distorted. Often I noticed that particular instruments or vocals sounded off or strange.
2) general characteristic is very
similar to tubes (especially Mullard or Toshiba) - I have xDuoo TA20 (with NOS tubes produced for Baldwin by Toshiba from 63y ) and EF400 has the same "creamy" style which I like (TA20 I am using occasionally for its midrange and vocals, but it lacks overall quality)
3)
going to better external amp (even only with RCA outputs and using the same 4.4 mm symmetrical cable with adapter to 6.3 mm) quickly shows downsides of EF400 internal amp. It creates big soundstage but lacks of precision unfortunately. With balanced output on EF400 (even it appeared to me clean and smooth) I started to be confused and couldn't focus on music in a way I am used to. I turned out that soundstage is strange. I can't locate sounds in space precisely even if I try hard. And I find it not really holographic around the head (with Goldplanar GL2K or ATH W1000Z just as example). Maybe because EF400 is wide, but the depth is compromised. Try for example tracks like Mazolewski Quintet - Crazy Girl or Yosi Horikawa - Bubbles.
4) there is
"static" noise (like with electrified clothes) in the background - very quiet but distracting and annoying. It appears in the same part of the particular song every time.
5)
going to my usual DAC /which is amazing PC sound card AIM SC808 (sic! but I didn't find better DAC for my preferences yet under 2K USD) upgraded with Korean opamps including RCA buffer + my Divaldi AMP with upgraded power supply/
shows how much music is lost with plenty of small details.. It is different level of resolution and clarity but still not as clinical as Topping or Matrix Audio products.
However even with all this disadvantages I really understand why the sound produced by EF400 is so enjoyable for many. This kind of smoothness and "natural, organic" feeling is what I am seeking for also. But I realized that there is too much to give up. And I am starting to think that this will be usually the case.. Less fatiguing and more "fluid" sound must be somehow less precise? At least with digital sources, because analog is a different story
One question - did anyone compare EF400 with other R2R DACs like Denafrips Ares II using external AMP?
