Introducing the Audeze MM-500!
- Thread starter Audeze
MRHiFiReviews
Formerly MRphotography
Sponsor: The Source AV
Thank you!careful and well-argued compare & contrast : thank you very much! There is no such thing as a free lunch...
Audeze MM 500 Mixing headphones vs LCD 5 Headphones; how close in performance are they?
TSAVJason
Stay updated on The Source AV at their sponsor profile on Head-Fi.
Andrew_WOT
- Jan 18, 2004
Do we expect comparison to LCD-X 2021 as promised earlier?
MRHiFiReviews
Definitely on my list!Do we expect comparison to LCD-X 2021 as promised earlier?
TSAVJason
Thanks for sharing our stuff, guys!
Really nice review! BTW I recall reading the MM-500 pads utilize adhesive. Is that problematic if / when one needs to replace them?
chargedcapacitor
No, the new Audeze pads will come with pre applied adhesive. You just pull the old pads off and stick the new ones on. Alternatively, if there is a defect in their application, you can send it back to Audeze and they can replace them for you.Really nice review! BTW I recall reading the MM-500 pads utilize adhesive. Is that problematic if / when one needs to replace them?
Do the MM-500 has glued plugs as in the LCD-5?
Some reviewers says that MM-500 and LCD-5 sound like HD-650, so how different and similar do they sound in comparison to the HD-650?
holofonze
Yes.Do the MM-500 has glued plugs as in the LCD-5?
Wow, I thought they were going to not do that after the complains that people gave them for their LCD-5sYes.
Perhaps this helps a bit to reassure the glued plugs issue is not a dealbreaker, but perhaps not. Certainly each individual decides what is a deal breaker for
spending their hard earned dollars: https://www.techpowerup.com/review/audeze-lcd-5-planar-magnetic-headphones/4.html
Andrew_WOT
- Jan 18, 2004
That's quite disappointing, so my older design cheaper LCD-X has proper screw in plugs?
Jonne Haven
One aspect that no one has seemed to mention AFAIK is that the MM-500 has a 90 mm driver diaphragm. A whole 16 mm less than the LCD-X.
Does this difference show up in the sound at all? How does it effect the bass performance? I'm a sub bass head, and I admit it so I need to have that LCD-X bass power with all of it's EQ-ability and innate punch and slam. I wonder if the MM-500 suffers in this area?
Anyone know?
Blessings,
-J
Anyone know?
Blessings,
-J
