Introducing the Audeze LCD-R!
Sep 10, 2021 at 6:39 PM Post #1,036 of 1,677
Hard tracking down much info on these, but assuming you could use these with a Raal speaker interface box and a speaker amp? Do know it will void the warranty, but just wondering. :)
Sep 10, 2021 at 7:26 PM Post #1,038 of 1,677
Apart from voiding warranty they would run just fine on the Raal amp and speakerbox Adapter tho.
Sep 10, 2021 at 10:33 PM Post #1,039 of 1,677
Audeze clearly states that any other amp would void warranty: "You MUST use the LCD-R with this particular Schiit amplifier. Using any other amplifier will void the warranty."
@number1sixerfan, did you grab one of the two that were on sale today?
Yea, I wouldn't want to void the warranty, but I also don't want to be bottlenecked by a Jot amp. But in either case was just curious, I'd start with the Jot amp regardless and assess whether it's worth the risk. And yes, I happened to luck up on a pair and the seller happened to be in my actual area for a local sale. Should be able to get them by Mon or Tues. :)
Sep 10, 2021 at 10:35 PM Post #1,040 of 1,677
Congrats! And may the fazors not disrupt your comfort.
Sep 11, 2021 at 12:04 AM Post #1,042 of 1,677
You have some solid gear in your signature. I'd be very curious to get your opinion on the LCD-R compared to what you have.
Sep 11, 2021 at 12:13 AM Post #1,043 of 1,677
Yea, his stuff is aight...
:L3000:
Sep 11, 2021 at 1:31 AM Post #1,044 of 1,677
Just one point of contention. The LCD-R rolls off pretty ****ing hard sub like 50hz if not even higher
If you can't EQ the low bass roll off, try breaking the seal between your head and the ear pads (sub bass is quite increased when wearing a baseball hat, or just pulling them slightly away from your head). Abyss is all about the broken seal to get their bass slam. I also think it takes a bit of the edge off of the shout that @WaveTheory refers to.
Or pad swapping might help.
Sep 11, 2021 at 2:48 AM Post #1,045 of 1,677
If I'm honest, I hadn't thought about trying to break the seal a bit. Ill try that on Monday for sure
Sep 11, 2021 at 3:31 PM Post #1,046 of 1,677
I have the number #10 – and these are pretty much 10/10:)
Sep 12, 2021 at 10:42 AM Post #1,048 of 1,677
@number1sixerfan, very nice, and congrats! Perhaps we will see a LCD-R cameo in your must-read flagship comparison thread.
Thank you both! Definitely will be comparing these against the CRBN on the way, along with everything else I have on hand. I'll probably only keep all the gear I have for the next 6 months or so before pairing down, so I'm definitely looking forward to sharing as much as I can before then. :)
Sep 13, 2021 at 5:50 PM Post #1,049 of 1,677
I ordered some Dekoni "Elite" Leather Pads to try with the LCD-R. Once I get them and change them out, I'll report any sonic differences that I hear. I'm sure the sound signature will be changed, but if it isn't too bad and the new pads address the comfort, these headphones will be keepers!
Cheers! :beerchug:
-HK sends
Sep 13, 2021 at 6:06 PM Post #1,050 of 1,677
