Introducing Shanling M8T - New Flagship Portable Android Player with Tubes
May 22, 2025 at 1:05 AM Post #541 of 543
Just received my M8T. Sorry if this was covered earlier in this thread, but what is the burn-in time for the 4.4mm output? I thought I read somewhere 100-150 hours and not the standard 200? And what might I expect to have changed after burn-in? Thank you.
May 23, 2025 at 8:04 PM Post #542 of 543
Dear @Shanling I bought the M8T with @JerryHead . He received it and I hope to receive it in 1 week.
I saw this warning in the M8T's user manual.
"Common Problems
1. It is recommended to use DC5V 2A adapter. Using the adapter withhigher voltage may damage M8T."
M8T is a dap that supports 18watt charging. 5V2A means 10 watt charging. Frankly, I'm confused. Could you please inform us about this? For example, would it be a problem if we charge it with 9V2A at 18 watts?
May 24, 2025 at 9:01 AM Post #543 of 543
"Common Problems
And, are the 3.0, 18W 3Amp wall chargers okay to use? If DC chargers should not be rated at above 2Amps, is it okay to use USB chargers rated at 3Amps?
