Any got any advice for how to optimize the sound of the M8T? Currently using UAPP, but open to other options that might give even better performance.
Introducing Shanling M8T - New Flagship Portable Android Player with Tubes
- Thread starter Shanling
chortya
- Feb 14, 2017
I stick to the stock app and Tidal without volume normalization.Any got any advice for how to optimize the sound of the M8T? Currently using UAPP, but open to other options that might give even better performance.
I am currently investigating the Wavelet App. Will edit this post with update if likely to be any good
Anybody tried using UAPP's EQ on the M8T? For me, the EQ does absolutely nothing.
@Shanling does the M8T disable EQ in UAPP and other player apps?
A quick search would have let you know this has been discussed. Someone made a reference to UAPP EQ not working in bit-perfect mode.Anybody tried using UAPP's EQ on the M8T? For me, the EQ does absolutely nothing.
Yep of course I searched and I saw that post. But you can turn bit perfect mode off in UAPP, so I don't think UAPP is the issue.
Does it work without bitperfect?Yep of course I searched and I saw that post. But you can turn bit perfect mode off in UAPP, so I don't think UAPP is the issue.
No, hence my post!
Total: 9 (members: 0, guests: 9)
