Introducing Shanling M7 - Portable Hi-Fi Android Player
- Thread starter Shanling
- Tags
- shanling shanling m7
sg2k
- Dec 18, 2012
Does some use it with CA Andromeda's (2020)? And is it a good Pairing?
received today fiio FD7. very nice sound out of the box on M7. and wireless on fiio utws5Does some use it with CA Andromeda's (2020)? And is it a good Pairing?
perry56205
Any suggestion on choosing whether H7 or M7?
Both seems to have a great sound.
im have only M7 and astell kern AK SR25ii. so,M7 without any questions better sound. sr25ii good but for other purposes. smaller lighter better battery etc. on cycling ride perfect...Any suggestion on choosing whether H7 or M7?
That why i given up on m7 although I like the sound signature.@Shanling has confirmed that the wifi issue is going to exist and they don't have any solution for that.
They are bluffing the users in name of firmware update but that never gonna happen.
They have cowardly accepted this fact.
kushgurjar8
You did absolutely right brother.That why i given up on m7 although I like the sound signature.
I raised it with @Shanling they just blocked me on Facebook and stopped replying me on mail.
They refused to help me.
Also confirmed no help.
Yikes that's crazy. If and when I move on from my M7 what companies do you recommend to purchase from in the future?You did absolutely right brother.
kushgurjar8
Fiio has good support and m17 is good dap.Yikes that's crazy. If and when I move on from my M7 what companies do you recommend to purchase from in the future?
Also you can go for hiby r2r daps , cayin daps latest dap.
Astel kern in premium segment.
Ibasso for module amps.
what outputs ohm is at m7 balanced or se outputs? does it suports very sensitive iems like campfire are rated at 8ohm?
Well, firstly, you really need to decide if you want all in one DAP or just a DAC/AMP with card slot. It makes huge difference when it comes to daily use.
On side of sound, I would say H7 is better than M7, but they differ in sound tuning, with M7 being the bit more neutral and balanced, while H7 will feel more V-Shaped and energetic in comparison.
As stated in our multiple emails, you can either send in your unit for check by our engineers, or await firmware updates. These are the only options in your situation.
It's less than 1 Ohm on both SE and Balanced output, so should be fine with these ultra-low impedance IEMs.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
perry56205
Thank you for the comparison.Well, firstly, you really need to decide if you want all in one DAP or just a DAC/AMP with card slot. It makes huge difference when it comes to daily use.
In terms of sound, for my situation if I usually listen to both Japanese pop songs and music (especially game/movie sountrack), which one will be more suitable ?
It's bit guessing, but I would say M7.Thank you for the comparison.
perry56205
Thank you for your advice.It's bit guessing, but I would say M7.
I think I will order the new blue-color M7. (My favourite Color)
