Introducing Shanling M7 - Portable Hi-Fi Android Player
- Thread starter Shanling
- Tags
- shanling shanling m7
does it is normal or not properly working M7. when connected via usb c to laptop win11 not recognize it. or i need wnother cable or M7 menu settings some edit? just want add music to dap memory
Firstly, your M7 is currently switched to USB DAC mode, if you want to use it for data transfer, you need to switch it to USB DISK mode.
You can find these basic tips on our website:
https://en.shanling.com/article-Android665Setup.html
Later, if you want to use M7 as USB DAC, you need to install USB drivers for it to work:
https://en.shanling.com/download/69
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
now switched to usb disk mode? so windows still not recognize it. sounds M7 top noch.Firstly, your M7 is currently switched to USB DAC mode, if you want to use it for data transfer, you need to switch it to USB DISK mode.
When you connect it to computer, you should get the standard system notification, where you can switch it to transfer files.now switched to usb disk mode? so windows still not recognize it. im bought it used here from headfier. sounds M7 top noch. but now learning it and see if it is fully working condition.
If this doesn't show up, it might be issue on cable. Not all USB-C cables are capable of data transfer, so might be good to try cable you know works fine with other phones.
If you purchased the played used, you can also check with the original owner.
and need download shanling drivers? im still not downloaded themWhen you connect it to computer, you should get the standard system notification, where you can switch it to transfer files.
Drivers are only needed for use of USB DAC. They are not needed for data transfer.and need download shanling drivers? im still not downloaded them
im instaled shanling usb drivers, so tablet shows connected M7, but windows still not recognize usb disk and not shows external disk connected. see pictures. somethink wrong? im changed few cables all works same.When you connect it to computer, you should get the standard system notification, where you can switch it to transfer files.
i no need use usb dac mode, just want connect to laptop and windoes dont see M7 hard drive... what a problem?
finally found on menu settings. now works.tidal works perfect and wifi ,bluetooth very strong . for my big hands size is comfy, and screen perfect, big letters for agged eyes from small 3.6” dap is big upgrade. now have happiness.
AudioAndCoffee
Lucky u, mine can't work with a few 5ghz wifi setup around my home and office. Basically i i use it plugging in a lan cable into the usb port.Scaldingly fast wifi on my M7. downloaded 9Gb music from Tidal very fast and only via 2.4Ghz shows screen. Sooo sweet sound via bluetooth with noble mystique.
..omg....for get 5ghz wifi i must see at my home router? 5ghz is faster vs 2.4ghz?Lucky u, mine can't work with a few 5ghz wifi setup around my home and office. Basically i i use it plugging in a lan cable into the usb port.
kushgurjar8
@Shanling has confirmed that the wifi issue is going to exist and they don't have any solution for that.
They are bluffing the users in name of firmware update but that never gonna happen.
They have cowardly accepted this fact.
