Pearl Lizard
Thank you very much for the answer!At airports be only scared for your undeveloped film when you see the new CT-scanners. For electronics such as M7 it's fine.
DX300 is a smooth sound.Hi all. I'm interested in shanling m7. But if we compare it with direct competitors, is shanling really that good compared to them? Namely: a&k kann alpha/kann max, ibasso dx300. What are the main differences in sound between these players? Which one is better for planar full-size headphones (not very complex)?
hi.こんにちは。3.5mm と 4.4mm のジャック出力はヘッドフォン専用ですか、それとも最大出力の純粋なライン出力にすることはできますか? 卓上型のハイエンドバイオラクトリックアンプとの接続について質問しています。
I understand. so then in the settings menu you can switch the pure line out output to the 3.5mm jack output, which then operates the dac output at maximum output? does this work on the 4.4mm output? 3.5 Jack - 2x rca cable that can be connected to a desktop amplifier, or would it also work with a 4.4 Jack - 2x xlr cable with symmetrical output?hi.
It has a lineout mode.
Hello. are the 3.5mm and 4.4mm jack outputs only for headphones, or can one of them also be a pure line output with maximum output power? I am asking because of the connection with a desktop high-end violactric amplifier.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
No, M7 can not be used as USB Bluetooth Transmitter.Hello, does anyone know if you can use the Shanling M7 as a usb pc dac and transmit to a bluetooth headset i have an mw200 and would like to have all my audo from pc and cloud on one device
No, it's not available and we are not planning to add it at this time.Hello, is there a way to limit the % to which the battery charges on the M7? If not, could that be added as a feature? I would like to charge the battery to a maximum of 80% to preserve the battery longevity, as I would like to keep this awesome device for a long time.
