Well……I’ve gone & done it…..and thinking is this the next expensive mistake ??
My Shanling M30 arrived today. I knew I’d be stressed taking it a part, ( given my poor cognitive function…..& when under stress, too. ) I put a SD card, didn’t seem to go all the way in, should it ?? It was sticking out slightly. There’s only one way an SD card will go into a device, right ??
I put it back together, clicked local files to scan, nothing found. I think there is something on the SD card, but I didn’t check it, before. Have I got to take it apart again ?? Can I connect to my computer, to see if it shows a SD card ?? I’ve already read it’s going to need drivers downloaded for Windows.
The next thing I’ve tried is Wi Fi, put in my password, keep getting message saying, “Is the password correct” ? I’ve just tried Ethernet & have a choice of DHCP or Static IP ( & I’m hopeless with internet configuring connections, neither worked & I don’t know what I’m supposed to type in ??
I’ve got an external hard drive plugged in, not even sure if plugged into the right place, but I’ve tried every orifice, that will fit.
I need major help !
I’d been clicking firmware updates & it was saying no netwopark connection, but just clicked again now & got this started 3% has probably taken more than 10 minutes & I still have to do server 2 ! Let alone finish server 1 !
I don’t know what I’m doing ! There seems to be no manual online, to presently access from my iPad ? Am I ever going to hear any music, from it ??
