Can anyone genuinely hear a difference with high resolution mode?
Introducing MOMENTUM 4 Wireless
- Thread starter Sennheiser
After latest firmware ANC does almost nothing... I wish I could go back to previous version...
You can do what I did. Return them.After latest firmware ANC does almost nothing... I wish I could go back to previous version...
I didn't care to get them again but guess if you buy them again they'll come with the original firmware.
I was too pissed off to try to do a reverse lookup and force an old firmware but might be possible too.
I would too but i dont have a receipt to return them, wouldve waited for the bose qc ultra insteadYou can do what I did. Return them.
Did you buy in store? If you paid by card you should be able to get a receipt. Otherwise, try to talk to the store, explain you don't have a receipt and try to go by Sennheisers warranty. The ANC is inexistent, you should be able to just return them claiming they don't work. I had no problems at the store after they confirmed the ANC was not working in my pair nor the demo on pair they had.I would too but i dont have a receipt to return them, wouldve waited for the bose qc ultra instead
Bought second hand, no card or receipt available... Thought they were good enough to blind buy but ig notDid you buy in store? If you paid by card you should be able to get a receipt. Otherwise, try to talk to the store, explain you don't have a receipt and try to go by Sennheisers warranty. The ANC is inexistent, you should be able to just return them claiming they don't work. I had no problems at the store after they confirmed the ANC was not working in my pair nor the demo on pair they had.
They were 40% less then original price and basically brand newBought second hand, no card or receipt available... Thought they were good enough to blind buy but ig not
PixelSquish
Previously known as idiotekniques
- Jul 13, 2005
I'm out of my return period, so basically screwed?
I was out of mine but claimed warranty: The product doesn't work. After explaining the situation and checking nor my unit or the demo unit worked, the owner processed muy return and said they'd check with Sennheiser to return all the units they had leftI'm out of my return period, so basically screwed?
PixelSquish
- Jul 13, 2005
I got mine at B&H, I'll give them a shot, thanks.I was out of mine but claimed warranty: The product doesn't work. After explaining the situation and checking nor my unit or the demo unit worked, the owner processed muy return and said they'd check with Sennheiser to return all the units they had left
Since ANC is software based, cant they improve it by updates?? Like the ANC is absolutely ass, they really badly need an update for it.
joe75
- Aug 19, 2009
I second that ( but it is also hardware based)Since ANC is software based, cant they improve it by updates?? Like the ANC is absolutely ass, they really badly need an update for it.
Well two firmwares ago at least it workedSince ANC is software based, cant they improve it by updates?? Like the ANC is absolutely ass, they really badly need an update for it.
Soundizer
- Dec 29, 2015
not sure what is going on but the noise cancelling has not changed on mine since newest firmware that adds 5band EQ. i am based in uk.
Soundizer
- Dec 29, 2015
new firmware confirms APTX HD codec is being processed. shown in the APP.
previously it was only showing AptX for AptX HD which was confusing. now i can see AptX HD being shown from transmission ANdroid device and being processed on Senn APP. this is excellent as many much much more expensive headphones (FOCAL BATHYS) have massively messed up by not including AptX HD with there APtX Adaptive license. what a shambles at £800.
now AptX by itself would never be offered to my King - King Charles. Atleast AptX HD for minimal Royalty approval.
Total: 8 (members: 0, guests: 8)
