Hi, I spend most of my time lurking and reading this forum. Today I have some input though.
short version: Sennheiser Momentum 4 win but don't look the part.
My fetish is wireless over ear headphones, tried wired a few times but the freedom of wireless is too much to resist. I really enjoy the Sennheiser RS180 that use Kleer (if you can find the SMS audio USB dongle that works with these from a PC then you have something great) and have had the Momentum 2 wireless since around their launch (they’re working fine except one ear phone needs a rubber band to hold it steady and the rocker button isn't really working). I recently bought the Hifiman Deva Pro with the R2R bluetooth adapter for at home listening. In addition, i received a set of Sony WH-H910N free with a new Sony phone, I didn't even know they were included. (I like Sony phones for the small sizes available, audio codecs, almost stock android and physical camera button).
This afternoon I spent a few hours testing in store:
Sony wh 1000xm5
B&W PX7 S2
vs
Sennheiser Momentum 2.0 (which is obviously inferior but my reference for noise cancelling headphones).
I've heavily EQed these with Wavelet to radically improve the sound (IMHO, which in this case is what matters)
This was not an A-B test due to there being two stores but that's pretty hard to do anyway without careful volume balancing between devices.
I did not compare the Sony WH-H910N because i find them effectively unuseable due to them being uncomfortable. the noise cancelling is better than the older M2 though.
The shops let me take the headphones into the street to test as well as in store noise.
I'll start with Sony XM5 because it's easiest:
Best noise cancelling but sounded harsh but with bloated bass. With nothing playing the noise cancelling is really very good though. They felt comfortable. Look bland. Only LDAC and basic SBS/AAC. This is limiting because it does tie you to products supporting LDAC (note that the Deva Pro has almost all the codecs).
It was quickly a no from me - unless I was going to start doing a lot of air travel and ANC became the absolute priority.
Now the B&W PX7 S2:
This is the headphone I wanted to like most...
It looks and feels the part. If you're spending >£300 on headphones to wear in public then this does matter. The only headphones of the new ones on trial that had any visual appeal.
The sound seemed a bit nasal to me, bass was quite a lot less impactful. Detailed yes but needed EQ (FWIW I also EQ the Deva Pro a lot to calm down the treble but being open backed they're in a different game to these ANC headphones).
Connectivity seemed flawless
ANC was better than the Momentum 2 but not a huge amount. This was a bit of a surprise considering reviews.
I spent a long time on these because I liked them in every respect except how they sounded out of the box (I say this like I've spend lots of time testing headphones when actually I previously ordered the M2 and the Deva Pro without listening).
I also liked the physical buttons rather than touch – It’s likely that physical buttons are actually more expensive to implement, build and also less robust so is probably going to die out.
EDIT: The store did tell me that they were box fresh and needed 40 hours burn in. I think this is probably BS though. If equipment needed to have burn in to sound good the manufacturer would make sure that was done for demo examples or in many cases sold new sets. Why risk underperforming?
However, I couldn’t justify the cost of an upgrade from the M2 based on the test I did.
Finally, the Sennheiser Momentum 4:
Starting with the bad: Physically disappointing. Not bad quality but even more bland than the Sony. It looks like this is where the cost saving is. The headband is nice but the ear cups look like they forgot to design them. That said, they do fit close to the head whereas the old M2/M3 head band was bulkier because it attached to the widest section of the earcup. Therefore overall they don’t look bad while worn, they just look like a bit cheaper than they are. The dual fixing of the yolk is probably stronger, it could just look posher.
Touch seems to work, as does connectivity. Really easy to get it all going.
ANC way better that M2 and significantly better than the B&W px7 s2 but not as impressive as Sony (marginally).
Easy to wear.
Aptx Adaptive is enough in this application (Android developer settings seem to think that they can do HD but the Sennheiser app doesn’t).
The sound of these was the only set to actually impress me the first time I played anything. I wanted to prefer the B&W even though they are more money but the M4 is quite a step up from what I'm used to in the M2.
I bought the M4...
So, I’ve done some more listening and they are very good. I fiddled with EQ and some graphs from Crinacle but found that the stock sound is pretty good. Harman curve tuned EQ reduces bass a bit but not much, they seem to be close to Harman tuned with a slight bass boost. The ANC can’t be turned off completely (only pass through), which suggests they rely on DSP to get the sound good but that’s fine if it works, which it does.
No LDAC but to my ears Aptx adaptive is as good in real world application. In fact, LDAC is in my experience less stable and outside of home listening isn’t usable in forced best quality mode. The truth is that really the ANC dominates the effect of the codecs as does the original recording quality (compare BBC Sounds to Deezer Hifi for example, even via the basic Aptx codec Deezer Premium is better by far than the BBC sounds app ever is). Aptx Adaptive is designed for this application.
So far no issues with my set of M4. Not really decided if I like the auto on/off and wear detection yet. Not sure I can really get over the look of them either. However, when I wear them I can see them!
Thanks for reading, if you got this far!
